[postgis-users] plpgsql - problem using variable schema and table names
David William Bitner
david.bitner at gmail.com
Thu Dec 17 07:38:32 PST 2009
Birgit,
The problem may be that you are creating a varchar variable for your schema
name and then you are trying to use it in an instance that is expecting a
database object. Anytime you are trying to insert variables as database
objects, you need to construct your query as a string and use execute
similar as to how you are creating your insert statement.
David
On Thu, Dec 17, 2009 at 9:27 AM, Birgit Laggner
<birgit.laggner at vti.bund.de>wrote:
> Dear list,
> I am trying to generalize a pl/pgsql function I have written (see
> below). I would like to define schema and table names, as well as
> certain column names, in the function call (as in the PostGIS function
> AddGeometryColumn) in order to use them to define schema and table names
> and everything else within the function queries.
> My problem is, that postgres doesn't recognize the defined variable
> names if I call them in a FROM clause or INSERT INTO. This is the error
> message:
> ERROR: Schema »schemaname« does not exist
> LINE 1: SELECT count( $1 ) from schemaname.table_a
> QUERY: SELECT count( $1 ) from schemaname.table_a
> CONTEXT: PL/pgSQL function "_laggner_b_pgintersection" line 16 at
> assignment
> I can't imagine that it should be impossible to use variable schema and
> table names in a plpgsql function. So, if anybody has suggestions, I
> would be quite happy.
> Thanks and regards,
> Birgit.
> My PostGIS version: 1.4.0-10.1
> My PostgreSQL version: 8.4.1-2.1
> My pl/pgsql function:
> CREATE OR REPLACE FUNCTION _laggner_b_pgintersection(schemaname
> varchar(20), table_a varchar(50), a_id varchar(20), table_b varchar(50),
> b_id varchar(20), intersection varchar(60)) RETURNS void AS
> $BODY$
> DECLARE
> counter integer;
> recordset_object RECORD;
> i integer;
> n integer;
> BEGIN
> counter := 0;
> n := count(a_id) from schemaname.table_a;
> --1. Intersection:
> FOR i in 1..n LOOP
> RAISE NOTICE 'Beginn Intersection Tabelle 1, Polygon %', i;
> FOR recordset_object IN
> SELECT
> a.a_id ,
> b.b_id,
> ST_intersection(a.the_geom, b.the_geom) AS the_geom
> FROM schemaname.table_a a, schemaname.table_b b
> WHERE a.a_id=i and
> st_intersects(a.the_geom, b.the_geom) and
> a.the_geom && b.the_geom
> LOOP
> execute
> 'INSERT INTO ''||schemaname||''.''||intersection||'' (''||a_id||'',
> ''||b_id||'', the_geom) '||
> 'VALUES ( '||
> ''||recordset_object||'.''||a_id||'', '||
> ''||recordset_object||'.''||b_id||'', '||
> ''||recordset_object||'.the_geom);';
> alternatively:
> INSERT INTO schemaname.intersection (a_id, b_id, the_geom)
> VALUES (
> recordset_object.a_id,
> recordset_object.b_id,
> recordset_object.the_geom);
> counter := counter + 1;
> RAISE NOTICE 'Schreibe Intersection-Polygon %', counter ;
> END LOOP;
> counter := 0;
> END LOOP;
> END;
> $BODY$
> LANGUAGE 'plpgsql' VOLATILE;
> ALTER FUNCTION _laggner_b_pgintersection(schemaname varchar(20), table_a
> varchar(50), a_id varchar(20), table_b varchar(50), b_id varchar(20),
> intersection varchar(60)) OWNER TO postgres;
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091217/488980d8/attachment.html>
