[postgis-users] ST_Difference lots of lines with lots of polygons
Christy Nieman
cnieman at dmsolutions.ca
Sat Dec 19 07:32:11 PST 2009
Kevin,
Thanks for responding. I'll give it a shot Monday morning when I'm back
at work, and will report back on how it goes.
Christy
On 12/18/2009 11:52 PM, Kevin Neufeld wrote:
> Hmm. Another use case for having topology in PostGIS ... if only :)
> Well, I think my approach would be to iterate through your polygons
> and do as you suggest, use ST_Difference, but use a collection of all
> the lines that overlap the polygon and the polygon as parameters.
> 1. First identity all the lines that potentially overlap a polygon
> CREATE TABLE overlapping_contours AS
> SELECT a.id AS poly_id, b.id AS cont_id, b.geom
> FROM poly a, contours b
> WHERE a.geom && b.geom;
> 2. Remove all original contour lines so you don't get duplicates later
> DELETE FROM contours WHERE id IN (SELECT cont_id FROM
> overlapping_contours);
> 3. Create multilinestring of the contours around every polygon (to be
> used as input into ST_Difference)
> CREATE TABLE grouped_contours AS
> SELECT poly_id, ST_Collect(geom) AS geom
> FROM overlapping_contours
> GROUP BY poly_id
> 4. Subtract the polys from the multilinestrings
> UPDATE grouped_contours a
> SET geom = ST_Difference(a.geom, b.geom)
> FROM polys b
> WHERE a.poly_id = b.id;
> 5. Expand and insert the mlines back into the contours table
> INSERT INTO contours (geom)
> SELECT (ST_Dump(geom)).geom
> FROM grouped_contours;
> None of this code is tested, and obviously you'll need to add indexes
> to your intermediate tables, but it might be a start. Note that
> PostgreSQL does not use more than one CPU at a time per query. I
> could see this taking quite a long time. To speed things up, you
> might try partitioning your polygons into 4 logical groups and run
> things concurrently. IE, in step one, add the filter AND a.id <
> 50000. Then, at the same time, run another query using AND a.id
> >=50000 AND a.id < 100000. Just a thought.
> Cheers,
> Kevin
> Christy Nieman wrote:
>> Hello,
>> I have been having difficulty figuring out how I might go about doing
>> a difference of many lines and polygons. For context, I have many (>
>> 3,000,000) contour lines that I want to difference based on many (>
>> 180,000) lakes. My goal is to remove the sections of the lines that
>> are within the polygons. I know that I can use ST_Difference(aLine,
>> aPolygon) to do this for one feature, but, what would the syntax look
>> like to go though all my line and all my polygons and return just the
>> lines/parts of lines that are outside of the polygons (and do this in
>> as quickly and resource-friendly way as possible)? The machine I am
>> working on is a relatively well-powered desktop (quad core, 6GB RAM).
>> Thanks for any insight/suggestions,
>> Christy
> postgis-users mailing list
