[postgis-users] Cleaning non valid multipolygon
Yves Moisan yves.moisan at boreal-is.com
Tue Feb 3 09:01:10 PST 2009
> -- Here's how I would rebuild your geometry
> SELECT ST_AsText(
>    -- properly deals with polygon holes
>    ST_BuildArea(
>       -- generate properly noded linework
>       ST_Union(
>          ST_Boundary(column1),
>          ST_Startpoint(ST_Boundary(column1))
> FROM ( VALUES ('MULTIPOLYGON(((
> 376249.7830234 8717655.6050357,
> 376268.0818048 8717666.0116082,
> 376265.2666038 8717670.5117466,
> 376247.812391 8717660.3864341,
> 376249.7830234 8717655.6050357)))'::geometry)) AS foo;
Hi Kevin,
I found out that about 20 features out of the 150 that I have a non
valid geometry for get a null geometry as a result of your proposed
solution.  I broke down the parts and found that in the cases where
things do not match buildarea fails on a multilinestring that does not
close.  Here is the breakdown for feature id = 122 with the culprit
lines in **bold**:
orignal geometry :
'MULTIPOLYGON(((
375838.7246768 8718403.0280759,
375844.0704528 8718410.3968027,
375904.0280814 8718366.8994515,
375898.8035535 8718359.4427696,
**375838.8459248 8718402.9401143,**
375838.7246768 8718403.0280759)))'
122 startpoint
"MULTIPOINT(375838.7246768 8718403.0280759)"
122 boundary
"MULTILINESTRING((
375838.7246768 8718403.0280759))"
122 Union:
'MULTILINESTRING(
(375838.7246768 8718403.0280759,375844.0704528 8718410.3968027),
(375844.0704528 8718410.3968027,375904.0280814 8718366.8994515),
(375904.0280814 8718366.8994515,375898.8035535 8718359.4427696),
(375898.8035535 8718359.4427696,**375838.8459248 8718402.9401143)**
You can see the union closes on a point very close to the origin point,
but not quite.  Can I either set some tolerance on the buildarea so it
snaps to the closest point in the case the multilinestring does not
close or enforce a constraint on the union so it produces a closed
linestring ?
If not, I'll correct them by hand.  You've already helped quite a bit !
TIA,
Yves
