[postgis-users] PostgreSQL minor patches are out
Paragon Corporation
lr at pcorp.us
Fri Feb 6 20:24:28 PST 2009
PostgreSQL 8.3.6 and other minor releases just came out.
One of the patches in 8.3.6 is one to fix that loss of data when clustering
gist indexes that was introduced in 8.3.5. So if you are running 8.3.5 you
probably should upgrade.
Anyrate notes from announce listed below
The PostgreSQL Project today released updates to all active branches of the
PostgreSQL object-relational database system, including versions 8.3.6,
8.2.12, 8.1.16, 8.0.20 and 7.4.24. These updates include two serious fixes,
for autovacuum crashes in version 8.1 and GiST indexing data loss in 8.3,
and those two versions should be updated as soon as possible.
These update releases also include patches for several low-risk security
holes, as well as up to 17 other minor fixes, depending on your major
version of PostgreSQL. Included as well are Daylight Savings Time changes
for Nepal, Switzerland and Cuba. See the release notes for full details.
The first serious issue affects users who are using version 8.1 with
Autovacuum, which will fail when XID rollover is required. The second
serious issue can cause data loss when CLUSTER is used with GiST indexes
(such as full text indexes) on version 8.3. Both issues are fixed in these
releases.
As with other minor releases, users are not required to dump and reload
their database in order to apply this update release; you can simply shut
down PostgreSQL and update its binaries. Users skipping more than one update
should check the release notes for extra, post-update steps.
As previously announced, only versions 8.2.12 and 8.3.6 of the Windows
binaries are being released, as we no longer support 8.0 and 8.1 on Windows.
-- Release Notes:
http://www.postgresql.org/docs/current/static/release.html
-- Installation Packages:
http://www.postgresql.org/download/
-- Source Code:
http://www.postgresql.org/ftp/source/
Please note: if you downloaded a copy of the 8.3.6 source code, or Windows
build 8.3.6-1, from www.postgresql.org before February 4th, you may have
received a copy which contains a bug. Please replace it with today's
download.
Leo
