[postgis-users] Cleaning non valid multipolygon
Stefan Keller
sfkeller at gmail.com
Sat Feb 7 15:28:08 PST 2009
I'd like to point out that this sounds similar to the ELIMINATE command in
ArcGIS.
And be aware that the area parameter is missing so called '*dumb-bell*'
polygons, which means sliver polygons which are very small but also very
long. In this case, an additional parameter would be of help: The
circumference.
Any ideas?
-S.
P.S. CLEAN is another cleansing command. See my next post.
2009/2/4 Yves Moisan <yves.moisan at boreal-is.com>
> Kevin,
> Thanx a lot. I ended up doing the few remaining by hand. I could start
> from the linestring and figure out where the bad vertex was. Not all
> the polygons I had closed and some even missed a side or two, so no hope
> for any algorithm there. I'll study what you're proposing and see how
> many remaining non valid geometries remain.
> Thanx again for your helpful comments.
> Yves
> Le mardi 03 février 2009 à 14:11 -0800, Kevin Neufeld a écrit :
> > Hi Yves,
> > No, you can't set a tolerance on building an area. Depending on your
> requirements, you can snap all the vertices in the
> > geometry to some grid so that such polygons do close.
> > Using OpenJUMP, I can see in your example that your linear ring falls
> short of about 0.15 units from closing. So, this
> > should work:
> > UPDATE mytable
> > SET the_geom = ST_BuildArea(
> > ST_Union(
> > ST_Boundary(ST_SnapToGrid(the_geom, 0.2)),
> > ST_Startpoint(ST_Boundary(ST_SnapToGrid(the_geom, 0.2)))
> > WHERE id = 122;
> > If snapping the entire geometry to a grid is not preferable to you, then
> you're left with some mucky business, but I
> > think you can do it.
> > 1. extract and node the exterior ring (your geometry runs back on itself
> so you can't tell where the start and endpoints
> > of the exterior ring lie)
> > 2. merge the ring to a single linestring (making the start and end points
> obvious)
> > 3. update the startpoint to be equal to the endpoint
> > 4. repolygonize.
> > CREATE TABLE tmp AS
> > SELECT id,
> > -- Create a single linestring
> > ST_LineMerge(
> > -- Remove overlapping segments
> > ST_Union(
> > ST_Boundary(the_geom),
> > ST_StartPoint(ST_Boundary(the_geom))
> > ) AS the_geom
> > FROM mytable
> > WHERE id = 122;
> > -- At this point, you should only have LINESTRINGs in tmp, not
> MULTILINESTRINGs. You should verify this to see if you
> > have other problems than just the endpoints not closing.
> > UPDATE mytable a
> > SET the_geom =
> > ST_BuildArea(
> > ST_SetPoint(b.the_geom, 0, ST_EndPoint(b.the_geom)))
> > FROM tmp b
> > WHERE a.id = b.id;
> > Yields a single polygon for id=122:
> > POLYGON ((
> > 375838.8459248 8718402.9401143,
> > 375844.0704528 8718410.3968027,
> > 375904.0280814 8718366.8994515,
> > 375898.8035535 8718359.4427696,
> > It would complicate things if you have holes in your non-closing
> polygons, but for starters this should do for you.
> > Hope that helps,
> > Kevin
> > Yves Moisan wrote:
> > > [cut] Can I either set some tolerance on the buildarea so it
> > > snaps to the closest point in the case the multilinestring does not
> > > close or enforce a constraint on the union so it produces a closed
> > > linestring ?
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090208/8fe61082/attachment.html>
