[postgis-users] WKTRaster status report
strk strk at keybit.net
Tue Feb 10 12:48:50 PST 2009
Thanks to three (3) brave sponsors stepping up steadly
we now have the capability to store rasters in a postgis
enabled database.
The rasters can be both in the database or just external
and only referenced.
Once imported/registered they can be selected using
well known operators already in use for GEOMETRY types.
The only downside is that you can't do much with them yet :)
There's still a lot to be sponsored, but you don't necessarely
need everything to make use of it. Simple register/retrive
(path-based) would only take a single funding slot to complete.
If you want to take a look at the current code (maybe to build
and run the automated testcases):
 svn co http://svn.refractions.net/postgis/spike/wktraster
If you're interested in sponsoring further steps, see:
 http://www.cef-cfr.ca/index.php?n=Membres.PierreRacineWKTRaster
And/or mail me or Pierre directly.
Thanks.
--strk;
 Free GIS & Flash consultant/developer      ()  ASCII Ribbon Campaign
 http://foo.keybit.net/~strk/services.html  /\  Keep it simple!
