[postgis-users] Using a buffer with a LineString covering the whole world
Chris Hermansen chris.hermansen at timberline.ca
Wed Feb 11 10:22:56 PST 2009
It might not be that bad, Paul, depending on the latitude of the start
and end points, which - USA <-> France - sounds like they might be
pretty close.  If it was say Seattle Paris, that would be ok.
Paul Ramsey wrote:
> that's really not a good option. mercator does not preserve
> length/distance, so the buffer would end up larger at one end than the
> other, and furthermore would not be the expected width, since it would
> be built far from the latitude of true scale.
> P.
> On Wed, Feb 11, 2009 at 8:52 AM, Pavel Iacovlev
> <iacovlev.pavel at gmail.com> wrote:
>> As an option you can use google mercator projection for the whole world. But
>> read carefully docs about it to understand the precision loss.
>> http://genuchten.blogspot.com/2008/04/srid-stuff-in-postgis.html would be a
>> good start.
>> On Wed, Feb 11, 2009 at 6:26 PM, Matthes Rieke <matthes.rieke.01 at gmail.com>
>> wrote:
>>> Hi all,
>>> I am currently running into this problem: I have a LineString in lat/long
>>> coordinates (SRID 4326 - going from USA to france). I now want to create a
>>> buffer in meters from this. So the normal way to transfrom the coordinates
>>> to a planar CRS, buffering, then transforming back to 4326 does not work
>>> (the Line is covering many UTM zones). What would be a reasonable solution
>>> for this problem?
>>> Thanks and regards,
>>> Matthes
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> http://iap.md, The future is open
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
