[postgis-users] Mapserver layer selects
Stephen Davies
sdc at sdc.com.au
Wed Feb 11 20:27:12 PST 2009
Could somebody please help me explain the results below.
The selects are cut-and-paste from postgresql log of cursor creation commands
from mapserver.
Both refer to the same point entity and both have the same map extent
constraint but the first query (correctly) returns one row while the second
returns none.
However, removing the extent constraint from the second query to give the
third, succeeds in returning the correct row.
Given that this is the only difference between queries 2 and three, one would
have to assume that the point is outside the extent.
However, query 1 shows that the point is actually in the extent - as does
eyeballing the geometries.
To further confuse me, increasing the extent in query 2 eventually results in
the entity being returned.
Cheers and thanks,
Stephen Davies
benparts=# SELECT * from swip2 WHERE (pid in (select probe.id from probe where
logger_id in (select id from logger where client_id=120)) and
rdate='2009-02-12 13:30:00') and (geom &&
setSRID( 'BOX3D(138.5356633 -34.9225467,138.5397151 -34.9184949)'::BOX3D,4283) );
rdate | state | pid | location | geom
2009-02-12 13:30:00 | 13.000 | 607 | Oval |
0101000020BB1000007ADFF8DA335161406551D845D17541C0
(1 row)
benparts=# SELECT * from swip3 WHERE (pid in (select probe.id from probe where
id | zname | pid | geom | rdate
(0 rows)
rdate='2009-02-12 13:30:00');
rdate
28 | Zone 2 | 607 | 0101000020BB1000007ADFF8DA335161406551D845D17541C0 |
2009-02-12 13:30:00
(1 row)
Stephen Davies Consulting P/L Voice: 08-8177 1595
Adelaide, South Australia. Fax : 08-8177 0133
Computing & Network solutions. Mobile:040 304 0583
VoIP:sip:1132210 at sip1.bbpglobal.com
