[postgis-users] points from st_distance
nicklas.aven at jordogskog.no nicklas.aven at jordogskog.no
Thu Feb 12 01:13:14 PST 2009
Thanks a lot
Regina is right about what I want to do and I agree that "any of the points that satisfies the below
condition is a solution to that"
I made some corresponding solution in avenue a few years ago but without buffer.
I don't think there is a practical problem, if you know about it, if you just get one of possible many points at the same shortest distance.
If the geometries is not snapped to a grid there should be very few cases when more than one point from each geometry represents the shortest line between the geometries if the precision of the calculations is good enough.
I still think it would be great with a built in function. I think it ought to be much more efficient to get the points at the same time as finding the closest distance instead of throwing them away inside the function and then finding them again outside the function.
This is not an acute problem for me right now but I can see a lot of possibilites from such a function. It would be possible to easy build snapfunctions. It would also increase the possibilites to analyze what's between two geometries.
If we could get the shortest line between geometries just as effective as we now get the shortest distance I think it would open many doors. Back in avenue this problem blocked the creative developing thinking many times. But that's just from my quite amateur point of view.
thanks again
Nicklas
2009-02-11 Paragon Corporation wrote:
Steve,
>Maybe I misunderstood his question. I thought what he was asking was
>1) since ST_Distance gives the distance between the 2 points of each
>geometry that are closest. What is that point(s) that it is using.
>So our thinking is is that any of the points that satisfies the below
>So say you have Geometry A and geometry B and you want to know what set of
>points on Geometry A are closest to Geometry B
>The answer would be
>SELECT ST_Intersection(A, ST_Buffer(B, ST_Distance(A,B)))
>Hope that helps,
>Regina
>-----Original Message-----
>From: postgis-users-bounces at postgis.refractions.net
>[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
>Woodbridge
>Sent: Wednesday, February 11, 2009 11:50 AM
>To: PostGIS Users Discussion
>Subject: Re: [postgis-users] points from st_distance
>Hmmmm, why not do something like:
>select *, ST_distance(point, object) as dist from table expand(point,
>min_distance) && object and dist <= min_distance order by dist limit 1;
>-Steve
>> Nicklas,
>> You are correct there is no function for doing this. We have on
>> occasion needed to do this ourselves and what we usually do is
>> 1) first find the minimum distance
>> 2) figure out which point/pointset on the geometry satisfies the
>> minimum distance using buffer and intersection (with minimum distance
>> being the buffer distance).
>> I think I have the code lying around here somewhere.
>> As far as ST_Distance goes. Haven't looked at the code that closely,
>> but it does some sort of recursive call and there could be more than
>> one point that satisfies the condition and it only cares about the
>> first one it comes across so such a thing may or may not be quite what
>> you are looking for.
>> Hope that helps,
>> Regina
>> *From:* postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
>> *nicklas.aven at jordogskog.no
>> *Sent:* Wednesday, February 11, 2009 4:47 AM
>> *To:* postgis-users at postgis.refractions.net
>> *Subject:* [postgis-users] points from st_distance
>> Hallo
>> I have a question or suggestion.
>> If I have missed some functionality please tell me.
>> The thing is I have often needed information about from which points
>> the distance in st_distance is calculated.
>> I mean, somewhere in the function the information have to be. Would it
>> be possible to build a new function which returned the distance,
>> startpoint, endpoint as array or something like that.
>> Am I right about that this functionality is missing and am I right
>> about that the points have to be identified somewhere in the function
>> and that it ought to be possible to present them in a function.
>> If I'm right so far I would like to come this as a suggestion.
>> I also have to thank you all for postgis.
>> It has been a very nice experience to start handling the gis analysing
>> and processing in database-environment.
>> My next step is to try to manage any of the procedural languages. Then
>> I guess I can do just anything with all the points and polygons out there
>> /Nicklas
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>__________ Information from ESET NOD32 Antivirus, version of virus signature
>database 3842 (20090210) __________
>The message was checked by ESET NOD32 Antivirus.
>http://www.eset.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090212/390b9752/attachment.html>
