[postgis-users] Re: AW: [mapserver-users] Mapserver layer selects
Stephen Davies
sdc at sdc.com.au
Fri Feb 13 16:54:28 PST 2009
I agree that my problem is more PostGIS related than Mapserver but it did
arise from a Mapserver session and this list is usually very helpful.
In addition, the constraint that seems to be in question is the extent
constraint added by Mapserver.
Swip2 and swip3 are views:
benparts=# \d swip2
View "public.swip2"
Column | Type | Modifiers
rdate | timestamp without time zone |
state | numeric |
pid | integer |
location | text |
geom | text |
View definition:
SELECT max(reading.rdate) AS rdate, sum(reading.rval) AS state, probe.id AS
pid, max(probe.location) AS location, max(probe.geom::text) AS geom
FROM probe, sensor, switch, reading
WHERE probe.id = sensor.probe_id AND sensor.id = reading.sensor_id AND
probe.switch_id = switch.id AND sensor.sensor_type::text = 'C'::text
GROUP BY probe.id, reading.rdate
ORDER BY max(reading.rdate) DESC;
benparts=# \d swip3
View "public.swip3"
id | integer |
zname | text |
pid | integer |
geom | geometry |
View definition:
SELECT DISTINCT zone.id, zone.name AS zname, probe.id AS pid, probe.geom,
reading.rdate
FROM reading, sensor, zone, probe, switch
WHERE reading.sensor_id = sensor.id AND sensor.zone = zone.id AND
zone.probe_id = probe.id AND probe.switch_id = switch.id AND
sensor.sensor_type::text = 'C'::text AND reading.rval = 1::numeric
ORDER BY zone.id, zone.name, probe.id, probe.geom, reading.rdate;
They are used to display irrigation probe and zone status in Mapserver layers.
The queries (should) return the same probe, switch and sensors - and without
the extent constraint (as in query 3), they do.
Cheers and thanks,
Stephen
On Friday 13 February 2009 19:27:55 Eichner, Andreas - SID-NLKM wrote:
> Altough this is more PostgreSQL/PostGIS related and should go to there
> list but I tried it and...
> strange, I can not reproduce your problem. This is what I did:
> create table swip3 (
> id int,
> zname varchar(20),
> pid int,
> geom geometry,
> rdate timestamp
> insert into swip3 values ( 28, 'Zone 2', 607, geomfromewkb( decode(
> '0101000020BB1000007ADFF8DA335161406551D845D17541C0', 'hex')),
> '2009-02-12 13:30:00'::timestamp );
> create table probe (
> int id,
> int logger_id
> insert into probe values ( 607, 1 );
> create table logger (
> int id,
> int client_id
> insert into logger values ( 1, 120 );
> SELECT * from swip3 WHERE (pid in (select probe.id from probe where
> logger_id in (select id from logger where client_id=120)) and
> rdate='2009-02-12 13:30:00') and (geom && setSRID( 'BOX3D(138.5356633
> -34.9225467,138.5397151 -34.9184949)'::BOX3D,4283) );
> id | zname | pid | geom
> | rdate
> 28 | Zone 2 | 607 | 0101000020BB1000007ADFF8DA335161406551D845D17541C0
> | 2009-02-12 13:30:00
> (1 Zeile)
> So I believe this has really nothing to do with MS.
Stephen Davies Consulting P/L Voice: 08-8177 1595
Adelaide, South Australia. Fax : 08-8177 0133
Computing & Network solutions. Mobile:040 304 0583
VoIP:sip:1132210 at sip1.bbpglobal.com
