[postgis-users] Re: Which postGIS functions to use?
Paragon Corporation
lr at pcorp.us
Mon Feb 16 01:50:57 PST 2009
Guy,
As an additional thought. Are you using the M coordinate to store measure
along. I think Steve may have pointed this out, but if you have an M
coordinate you are using, then you will want to probably use
http://postgis.refractions.net/documentation/manual-svn/ST_Locate_Along_Meas
ure.html
Hope that helps,
Regina
-----Original Message-----
Sent: Monday, February 16, 2009 4:45 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Re: Which postGIS functions to use?
Guy,
What spatial ref sys is your data? Is it longlat or meter/ft based?
As I think Steve Woodbridge mentioned, I think you'll want to take a look at
the linear referencing functions documented here
http://postgis.refractions.net/documentation/manual-svn/ch07.html#Linear_Ref
erencing
In particular -- ST_Line_Interpolate_point
http://postgis.refractions.net/documentation/manual-svn/ST_Line_Interpolate_
Point.html
So if you know the overlap is 200m in and the network component is 400m and
you are using a non-long lat coordinate system, then your fraction will be
0.50
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Guy
Thomas
Sent: Monday, February 16, 2009 2:31 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Re: Which postGIS functions to use?
Sorry if I wasn't clear enough. I know the length of the overlapping piece
of the quay with the network component. I want to calculate the end
coordinate (a point) of the quay on the network component.
quay
x--------------------y
network component
a--------------k-----------------b
The overlap is, let's say, 200m. I want to calculate point k, its
coordinates, on the network component starting from point a, k being 200m
away from a.
postgis-users-request at postgis.refractions.net wrote:
> Send postgis-users mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> postgis-users-owner at postgis.refractions.net
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of postgis-users digest..."
> Today's Topics:
> 1. Why Multiply? Why not? ( Mohamad Solikin (via Multiply) )
> 2. RE: Which postGIS functions to use? (Paragon Corporation)
> 3. Re: Which postGIS functions to use? (Stephen Woodbridge)
> 4. PostGIS functions inside triggers (Eduin Yezid Carrillo Vega)
> Message: 1
> Date: Sun, 15 Feb 2009 1:43:34 -0500
> From: " Mohamad Solikin (via Multiply) " <multiply at multiply.com>
> Subject: [postgis-users] Why Multiply? Why not?
> Message-ID: <200902150643.n1F6hqCr021656 at px526-fe.Multiply.com>
> Content-Type: text/plain; charset=utf-8
> Check out my Multiply site
> I set up a Multiply site with my pictures, videos and blog and I want
> to add you as my friend so you can see it. First, you need to join
> Multiply! Once you join, you can also create your own site and share
> anything you want, with anyone you want.
> Here's the link:
> http://multiply.com/si/5iVP2eBXx98C1NJENpUzPg
> Thanks,
> Mohamad
> Stop e-mails, view our privacy policy, or report abuse:
> http://multiply.com/bl/5iVP2eBXx98C1NJENpUzPg
> We haven't added your email address to any lists, nor will we share it
> with anyone at any time.
> Copyright 2009 Multiply Inc.
> 6001 Park of Commerce, Boca Raton, FL 33487, USA
> Message: 2
> Date: Sun, 15 Feb 2009 05:39:28 -0500
> From: "Paragon Corporation" <lr at pcorp.us>
> Subject: RE: [postgis-users] Which postGIS functions to use?
> To: "'PostGIS Users Discussion'"
> <postgis-users at postgis.refractions.net>
> Message-ID: <F96D34A9696B465F9FE7D73585115CC7 at b>
> Content-Type: text/plain; charset="us-ascii"
> I don't quite understand your question.
> Are you trying to get the length of the intersection of the 2? So
> that part of the network component that falls within the quay?
> In that case it would be something of the form
> SELECT ST_Length(ST_Intersection(netcomponent.the_geom,
> quay.the_geom))
> Which assumes your netcomponent is defined as a LINESTRING (you can
> use ST_MakeLine
> http://postgis.refractions.net/documentation/manual-svn/ST_MakeLine.ht
> ml
> if you have 2 points and no line)
> And quay is some sort of polygon.
> Hope that helps,
> Regina
> gt at fks.be
> Sent: Saturday, February 14, 2009 11:31 AM
> Cc: guythomas at telenet.be
> Subject: [postgis-users] Which postGIS functions to use?
> I have a "network component" (= part of a waterway) defined by 2
> coordinates.
> I know how to calculate the length of that component.
> However, another component, let's say a quay, overlaps with the
> component. I know how far it overlaps (in meters) with the component
> from the beginning coordinate and I want to calculate the end
> coordinate of the quay (that should be on the network component).
> How do I do this?
> Thank you
> Message: 3
> Date: Sun, 15 Feb 2009 11:15:40 -0500
> From: Stephen Woodbridge <woodbri at swoodbridge.com>
> Subject: Re: [postgis-users] Which postGIS functions to use?
> To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
> Message-ID: <49983FAC.3010603 at swoodbridge.com>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> I'm not sure if I understand you question correctly, but here is a
> solution for my understanding.
> So you have a network component that is partially overlapped by the
> quay and you know the length along the network component where the
> overlap starts or stops. You can extract the part of the network
> component that overlap with ST_Intersection or ST_Difference as Regina
> suggests. You can also do this using the linear referencing functions
> which might be
> faster:
> From start of netcomponent to your distance of intersection:
> SELECT ST_line_substring(netcomponent.the_geom, 0.0,
> dist_meters/ST_length_spheroid(netcomponent.the_geom,spheroid))
> From your distance of intersection to the end of the netcomponent:
> dist_meters/ST_length_spheroid(netcomponent.the_geom,spheroid), 1.0)
> If you just want the point of intersection with the quay then this
> should do it:
> SELECT ST_locate_along_measure(netcomponent.the_geom,
> All these functions assume your geometry is in units degrees and you
> will need to define an appropriate value for spheroid like:
> SPHEROID[<NAME>,<SEMI-MAJOR AXIS>,<INVERSE FLATTENING>]
> for example:
> 'SPHEROID["GRS_1980",6378137,298.257222101]'
> -Steve
>> quay.the_geom))
>> use ST_MakeLine
>> tml
>> Hope that helps,
>> Regina
>> gt at fks.be
>> coordinates.
>> How do I do this?
>> Thank you
> Message: 4
> Date: Sun, 15 Feb 2009 12:16:26 -0500
> From: Eduin Yezid Carrillo Vega <yecarrillo at gmail.com>
> Subject: [postgis-users] PostGIS functions inside triggers
> Message-ID:
> <75b8f7010902150916h29b26a31gac02da86fd31d2c8 at mail.gmail.com>
> Maybe I miss something, but ST_Contains isn't available inside this
> trigger. It returns empty values trying to get which polygon in table2
> contains a recently inserted point on table1. table1.the_geom value is
> filled correctly but table1.table2_id value is null. Tried ST_Within
> and ST_Intersects also.
> CREATE TABLE table1
> table1_id serial NOT NULL,
> lon character varying(30),
> lat character varying(30),
> table2_id character varying(200),
> the_geom geometry,
> CONSTRAINT table1_pkey PRIMARY KEY (table1_id),
> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
> 'POINT'::text OR the_geom IS NULL),
> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
> WITH (OIDS=FALSE);
> CREATE TRIGGER table1_change
> AFTER INSERT OR UPDATE OR DELETE
> ON table1
> FOR EACH ROW
> EXECUTE PROCEDURE table1_change();
> CREATE TABLE table2
> gid serial NOT NULL,
> table2_id character varying,
> the_geom geometry,
> CONSTRAINT table1_pkey PRIMARY KEY (table2_id),
> 'MULTIPOLYGON'::text OR the_geom IS NULL),
> WITH (OIDS=FALSE);
> CREATE OR REPLACE FUNCTION table1_change()
> RETURNS trigger AS
> $BODY$
> DECLARE
> the_point geometry;
> a_row table2%ROWTYPE;
> BEGIN
> IF tg_op = 'INSERT' THEN
> SELECT ST_GeomFromText('POINT(' || new.lat || ' ' || new.lon ||
> ')',4326) INTO the_point;
> SELECT * FROM table2 WHERE ST_Contains(table2.the_geom,
> the_point) INTO a_row;
> UPDATE table1 SET
> table2_id = a_row.table2_id,
> the_geom = the_point
> WHERE table1_id=new.table1_id;
> END IF;
> RETURN new;
> END
> $BODY$
> LANGUAGE 'plpgsql' VOLATILE
> COST 100;
> ALTER FUNCTION table1_change() OWNER TO postgres;
> Triggered with:
> INSERT INTO table1(table1_id, lon, lat) VALUES
> (999,-73.138583333333,7.0854783333333);
> Eduin Yesid Carrillo Vega
> Ingeniero Civil, Esp. Sistemas de Información Geográfica Bogotá D.C.,
> Colombia
> End of postgis-users Digest, Vol 76, Issue 15
Guy Thomas guy.thomas at fks.be
fks bvba - Formal and Knowledge Systems http://www.fks.be/
Stationsstraat 108 Tel: ++32-(0)11-21 49 11
B-3570 ALKEN Fax: ++32-(0)11-22 04 19
