[postgis-users] PostGIS on VISTA
johnvb john.vanbreda at biodiverseit.co.uk
Tue Feb 17 06:04:32 PST 2009
I am using PostGIS on Vista with UAC enabled, and have not observed this
problem at all. I did have to Run as Administrator when installing
PostgreSQL and PostGIS though, but that was the only issue I encountered
related to Vista.
Cheers
John
Ravivundavalli wrote:
> Hi,
> having some problems of PgSQL and PostGIS on VISTA
> I use OpenJUMP as a front end.
> 1. Have been using PostGIS since months without problem.
> 2. Then suddenly PostGIS stopped functioning.
>    'Server not accepting connection'
>    It took quite an effort to re-install.
>    Followed inputs from user interaction..
>    UAC was changed, and a Admin user created.. then it installed.
>    I have again re-enabled UAC
> 3. To day, it again stopped functioning..
>    It has not accepted the password..'Server not accepting connection'
> 4. Just to try out, I have changed UAC..(disabled UAC)
>    and then it worked..
> Any other VISTA users may pl react
> cheers
> Ravi Kumar
> postgis-users mailing list
View this message in context: http://www.nabble.com/PostGIS-on-VISTA-tp22002242p22056809.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
