[postgis-users] Re: Mapserver layer selects - resolved
Paragon Corporation
lr at pcorp.us
Tue Feb 17 21:01:56 PST 2009
Stephen,
Could be. I think I had similar issues with my triggers where the actual
bounding box of the geometry was different from the stored one.
I forgot about that since it hasn't been an issue recently and I have
upgraded since.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen
Davies
Sent: Tuesday, February 17, 2009 11:13 PM
To: postgis-users at postgis.refractions.net
Cc: MAPSERVER-USERS at lists.osgeo.org
Subject: [postgis-users] Re: Mapserver layer selects - resolved
I have finally resolved this issue by upgrading to 8.3.6 and then dropping
and recreating the relevant GIST geometry index.
Could this be a manifestation of the GIST bug fixed in 8.3.6?
Cheers,
Stephen
On Saturday 14 February 2009 13:55:08 Stephen Davies wrote:
> Further to my earlier question.
> I have experimented further and now get the following results:
> benparts=# SELECT * from swip3 WHERE (pid in (select probe.id from
> probe where logger_id in (select id from logger where client_id=120))
> and
> rdate='2009-02-12 13:30:00') and (geom && setSRID( 'BOX3D(138.5356633
> -34.99,138.5397151 -34.8)'::BOX3D,4283) ); id | zname | pid | geom |
> rdate
> (0 rows)
> and
> -34.99,138.6 -34.9)'::BOX3D,4283) );
> rdate
>------------------- 28 | Zone 2 | 607 |
>0101000020BB1000007ADFF8DA335161406551D845D17541C0 | 2009-02-12
>13:30:00
> (1 row)
> benparts=# SELECT astext(geom) from swip3 WHERE (pid in (select
> probe.id from probe where logger_id in (select id from logger where
> client_id=120)) and rdate='2009-02-12 13:30:00');
> astext
> POINT(138.53758 -34.920449)
> (1 row)
> The only thing that changes between query 1 and query 2 is that I have
> increased the "extent constraint".
> However, as query 3 shows, the point is clearly within the smaller
> original extent so should have been returned by query 1.
> No???
> Cheers,
> Stephen
Stephen Davies Consulting P/L Voice: 08-8177
1595
Adelaide, South Australia. Fax : 08-8177
0133
Computing & Network solutions. Mobile:040 304
0583
VoIP:sip:1132210 at sip1.bbpglobal.com
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
