[postgis-users] Error installing PostGIS 1.3.5 on Windows Server 2003 Enterprise R2
Frode Wiseth Jørgensen frodewj at gmail.com
Wed Feb 18 05:15:39 PST 2009
I'm having the same problem.
Did you find a solution?
Regards
Frode
Gianfranco Mangiarano wrote:
> Sure, I'm runnin as Administrator.
>>> Hi Leo,
>>> I used two methods:
>>> 1) Install Postgis through the stack builder module
>>> 2) Download and install PostGIS using the offline installer
>> Are you running as an Administrator? You'll need to do this in order
>> to make sure you have permissions to write to the PostgreSQL
>> installation directory.
>> ATB,
>> Mark.
> postgis-users mailing list
View this message in context: http://www.nabble.com/Error-installing-PostGIS-1.3.5-on-Windows-Server-2003-Enterprise-R2-tp21917830p22078444.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
