[postgis-users] PostGIS functions inside triggers
Eduin Yezid Carrillo Vega
yecarrillo at gmail.com
Thu Feb 19 09:01:23 PST 2009
Thanks Ralf. Both tables have primary keys and GeomFromText definition
is fine now. Still getting empty values.
Eduin Yesid Carrillo Vega
Bogotá D.C., Colombia
On Mon, Feb 16, 2009 at 1:40 PM, Ralf Suhr <gisbox at web.de> wrote:
> Mhm my fault.
> Change one line in the function.
> NEW.the_geom := ST_GeomFromText('POINT(' || new.lat || ' ' || new.lon ||
> ')',4326);
> And one line in the definition of the table two.
>>CREATE TABLE table2
>> gid serial NOT NULL,
>> table2_id character varying,
>> the_geom geometry,
> CONSTRAINT table2_pkey PRIMARY KEY (table2_id),
>> CONSTRAINT enforce_dims_the_geom CHECK (ndims(the_geom) = 2),
>> CONSTRAINT enforce_geotype_the_geom CHECK (geometrytype(the_geom) =
>>'MULTIPOLYGON'::text OR the_geom IS NULL),
>> CONSTRAINT enforce_srid_the_geom CHECK (srid(the_geom) = 4326)
>>WITH (OIDS=FALSE);
> thats all.
> Ralf
