[postgis-users] Basic question #1 Managing temporality in spatial data - MAUP over time
Ben Madin ben at remoteinformation.com.au
Thu Feb 19 19:20:31 PST 2009
Thanks Paul,
I will check out contrib/seg - it sounds like it might have
application for another (unrelated) issue I am dealing with. It's a
neat solution (as are most of these modules) to a problem.
cheers
Ben
On 20/02/2009, at 5:01 AM, postgis-users-
request at postgis.refractions.net wrote:
> Date: Wed, 18 Feb 2009 16:35:06 -0800
> From: Paul Ramsey <pramsey at opengeo.org>
> Subject: Re: [postgis-users] Basic question #1 Managing temporality in
> Your approach is fine.
> If you were dealing with much larger data collection, you'd find that
> over time your spatial selectivity starts to go down, as more and more
> data piles up in the same x/y area over time. That's when it's time to
> add an indexed time-range to your tuples, so that you can
> simultaneously index select on spatial and temporal ranges. For that I
> would suggest adding a time range column containing 'seg' objects (see
> ./contrib/seg) with the end values derived from unix timestamps.
> Paul
> On Wed, Feb 18, 2009 at 4:24 PM, Ben Madin <ben at remoteinformation.com.au
> > wrote:
>> I hope no one minds this, but I have to deal with some changes to
>> my data,
>> and thought it might be a good opportunity to ask the basic
>> questions I've
>> been dwelling on for some time.
>> Having just received a new set of the spatial data I am working with
>> (shapefiles of administrative regions), I am unsurprised to find
>> that about
>> 15 districts have gone (been amalgamated), some new ones appeared,
>> and
>> indeed one entire province removed!
>> My intention was to add two columns to my gis data table -
>> geom_start_validity & geom_end_validity, and revise my queries (which
>> normally are analysing / displaying movement information) to choose
>> the
>> appropriate geometry depending on the date range of the query.
>> Is the approach sound? (Is this a reasonable idea? Am I completely
>> off track
>> here? Will this make my table difficult to index? Should I find all
>> the
>> polygons which are the same and delete the duplicates, extending the
>> validity dates?)
>> (The interface which relates to the entry of movements would also
>> be amended
>> to deliver a different set of provinces and districts depending on
>> the date
>> of the movements. How I deal with movements that occur over the
>> transition
>> is beyond me so far!)
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
