[postgis-users] ST_AsSVG crashes with large/complex geometries
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Fri Feb 20 21:34:37 PST 2009
Hi Mark,
Sorry for the delay - I've been on the road a bit. I've got
postgresql-8.3.6, and postgis-1.3.5, both installed from the Fedora 10
repos.
I'll report this as a bug sometime in the next few days when I have a
bit of time to put a sample together...unless anyone has any other
suggestions?
Mike
> Message: 22
> Date: Thu, 19 Feb 2009 14:18:16 +0000
> From: Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
> Subject: Re: [postgis-users] ST_AsSVG crashes with large/complex
> geometries
> To: mgleahy at alumni.uwaterloo.ca, PostGIS Users Discussion
> <postgis-users at postgis.refractions.net>
> Message-ID: <499D6A28.5080102 at siriusit.co.uk>
> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
> Mike Leahy wrote:
>> > Hello list,
>> > I'm wondering if anyone has run into issues with st_assvg locking up
>> > postgresql. I have an application that generates svg from unioned sets
>> > of geometries. So far it has been working pretty well, except I just
>> > tested it with very large sets of geometries, and it invariably locks up
>> > the backend database without any errors etc. I could send a sample
>> > geometry if that would help, but I think this can probably be done with
>> > any dataset. I've verified that the problem is not with st_union, as it
>> > outputs a geometry just fine...it's only when it gets to st_assvg does
>> > it freeze things...there is no CPU activity. I do see this in the pg_log:
>> > *** glibc detected *** postgres: postgres testdb [local] SELECT:
>> > realloc(): invalid next size: 0x000000000220f410 ***
>> > Am I just expecting too much of the st_assvg function, or is this
>> > something that might be fixable?
>> > Thanks for any advice,
>> > Mike
> Hi Mike,
> Yeah, that sounds like a bug. What versions of PostgreSQL/PostGIS are
> you using? You may want to open a bug with a sample geometry on the
> PostGIS bugtracker.
> ATB,
> Mark.
