[postgis-users] ST_AsSVG crashes with large/complex geometries
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Sat Feb 21 06:10:52 PST 2009
Sorry...forgot the link:
http://code.google.com/p/postgis/issues/detail?id=119
Mike Leahy wrote:
> Ok...the issue is posted here. There's sample geometries there if you
> want to give it a shot Marco.
> Mike Leahy wrote:
>> Hi Mark,
>> Sorry for the delay - I've been on the road a bit. I've got
>> postgresql-8.3.6, and postgis-1.3.5, both installed from the Fedora 10
>> repos.
>> I'll report this as a bug sometime in the next few days when I have a
>> bit of time to put a sample together...unless anyone has any other
>> suggestions?
>> Mike
>>> Message: 22
>>> Date: Thu, 19 Feb 2009 14:18:16 +0000
>>> From: Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
>>> Subject: Re: [postgis-users] ST_AsSVG crashes with large/complex
>>> geometries
>>> To: mgleahy at alumni.uwaterloo.ca, PostGIS Users Discussion
>>> <postgis-users at postgis.refractions.net>
>>> Message-ID: <499D6A28.5080102 at siriusit.co.uk>
>>> Content-Type: text/plain; charset=ISO-8859-1; format=flowed
>>> Mike Leahy wrote:
>>>> > Hello list,
>>>> > > I'm wondering if anyone has run into issues with st_assvg
>>>> locking up > postgresql. I have an application that generates svg
>>>> from unioned sets > of geometries. So far it has been working
>>>> pretty well, except I just > tested it with very large sets of
>>>> geometries, and it invariably locks up > the backend database
>>>> without any errors etc. I could send a sample > geometry if that
>>>> would help, but I think this can probably be done with > any
>>>> dataset. I've verified that the problem is not with st_union, as it
>>>> > outputs a geometry just fine...it's only when it gets to st_assvg
>>>> does > it freeze things...there is no CPU activity. I do see this
>>>> in the pg_log:
>>>> > > *** glibc detected *** postgres: postgres testdb [local] SELECT:
>>>> > realloc(): invalid next size: 0x000000000220f410 ***
>>>> > > Am I just expecting too much of the st_assvg function, or is
>>>> this > something that might be fixable?
>>>> > > Thanks for any advice,
>>>> > Mike
>>> Hi Mike,
>>> Yeah, that sounds like a bug. What versions of PostgreSQL/PostGIS are
>>> you using? You may want to open a bug with a sample geometry on the
>>> PostGIS bugtracker.
>>> ATB,
>>> Mark.
