[postgis-users] Error using PostGIS and GEOM
Giri
giriprakash at gmail.com
Tue Feb 24 09:39:35 PST 2009
HI,
I recently installed the PostGIS to use it with Geoserver, the project that
uses the PostGIS needs the GEOM extension. So I installed the GEOM and
rebuilt the PostGIS, now I am getting the following error:
the PostGIS is running in Linux.
any help will be appreciated!.
The following exception was thrown:
- class java.io.IOException: An SQL exception occurred: ERROR: could not
load library "/usr/lib64/pgsql/liblwgeom.so": libgeos_c.so.1: cannot open
shared object file: No such file or directory
Details:
java.io.IOException: An SQL exception occurred: ERROR: could not load
at org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java:1124)
at org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java:994)
Thanks!
Giri
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090224/2b7c1188/attachment.html>
