[postgis-users] Error using PostGIS and GEOM
Giri
giriprakash at gmail.com
Wed Feb 25 08:00:33 PST 2009
Thanks for your responses, I have tried all your suggestions, and also ended
up re-installing the PostGIS. Using the Geoserver, I am trying to add a new
Feature type with the polygon It now complains about the following error
- class org.geotools.data.DataSourceException: Could not count Request
All Features
- class org.postgresql.util.PSQLException: ERROR: function
extent(geometry) does not exist
org.geotools.data.DataSourceException: Could not count Request All Features
at
org.geotools.data.postgis.PostgisFeatureStore.bounds(PostgisFeatureStore.java:764)
at
org.geotools.data.postgis.PostgisFeatureStore.getBounds(PostgisFeatureStore.java:676)
at
org.geotools.data.postgis.PostgisFeatureStore.getBounds(PostgisFeatureStore.java:653)
at
org.geoserver.feature.FeatureSourceUtils.getBoundingBoxEnvelope(FeatureSourceUtils.java
Caused by:
org.postgresql.util.PSQLException: ERROR: function extent(geometry) does not
exist
at
org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.j
Not sure what is causing this error.
thanks!
Giri
On Wed, Feb 25, 2009 at 5:14 AM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> ???(Sinboy Zhang) wrote:
> I got the same problem.
>> OS:CentOS 5.2
>> PostgreSQL:8.2.6
>> Geos:3.0.0
>> proj:4.6.0
>> postgis:1.3.2
>> A few months ago,i installed them successully on Fedora 7,now a error
>> boked when i installed on CentOS:
>> ERROR: could not load library "/usr/local/postgis/lib/liblwgeom.so":
>> libgeos_c.so.1:
>> cannot open shared object file: No such file or directory
>> But the file liblwgeom.so was existed surely in /usr/local/postgis/lib, i
>> added /usr/local/postgis/lib to /etc/ld.conf.d/local.conf and execute
>> ldconfig ,final restart postgresql ,but the error still exist.
> The error is telling you that PostgreSQL can't see libgeos_c.so.1 - you
> need to add the location of this file (normally /usr/local/lib) to
> /etc/ld.conf.d/local.conf and then run ldconfig so the OS can see it. On
> some older machines you may also have to restart the PostgreSQL server too.
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090225/d9f656fa/attachment.html>
