[postgis-users] order of points in ST_ConvexHull
Sufficool, Stanley ssufficool at rov.sbcounty.gov
Thu Feb 26 12:51:22 PST 2009
Pull the centroid of the geometry and use generate_series() / pointn()
to "explode" the points and test each point for above & right of
centroid, above and left of centroid, etc...
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Armin Burger
> Sent: Thursday, February 26, 2009 11:57 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] order of points in ST_ConvexHull
> Hello
> I need to find a possibility to identify upper-left,
> upper-right, etc.
> corners of +/- rectangular polygons. I.e. polygons with
> guranteed just 4
> corners, but with a shape that is typically between a rectangle and a
> rhomb. The polygons define the geometry of image boundaries ("image
> footprints"). But it cannot be guaranteed which point in the polygon
> corresponds to which corner since the order of points during geometry
> creation is unknown.
> One idea was to use ST_ConvexHull(geometry) since for this
> very simple
> polygons the convex hull seems to be identical with the geometry. It
> looked to me that the order in this convex hull was:
>    lower-right, lower-left, upper-left, upper-right
> Does anybody know if this order is always like that or can this order
> change? Would anybody know another method to identify which
> point of the
> polygon corresponds to which corner?
> Regards
> Armin
> postgis-users mailing list postgis-users at postgis.refractions.net
