[postgis-users] Error en postgres
Javier Andrés Mena Zapata
javimena at gmail.com
Fri Feb 27 06:32:47 PST 2009
Mmmm... I think your question should be in english not in spanish.
How are you installing postgis? Does the package exists among the packages
list iun synaptic?
"Saludos",
On Fri, Feb 27, 2009 at 10:09 AM, Z.M. <nramire1 at rosario.gov.ar> wrote:
> Hola a todos. Estuve tratando de instalar postgis sobre postgresql
> Instale postgresql desde el gestor de paquetes synaptic de la distribucion
> de debian.
> al intentar instalar postgis me da el siguiente error:
> casa:/home/usuario# psql -version
> psql: FATAL: no existe la base de datos «root»
> casa:/home/usuario# psql --version
> psql (PostgreSQL) 8.1.11
> incluye soporte para edición de línea de comandos
> casa:/home/usuario# cd postgis-1.3.5
> casa:/home/usuario/postgis-1.3.5# make # make install
> ./configure
> checking for gcc... gcc
> checking for C compiler default output file name... a.out
> checking whether the C compiler works... yes
> checking whether we are cross compiling... no
> checking for suffix of executables...
> checking for suffix of object files... o
> checking whether we are using the GNU C compiler... yes
> checking whether gcc accepts -g... yes
> checking for gcc option to accept ISO C89... none needed
> checking for g++... g++
> checking whether we are using the GNU C++ compiler... yes
> checking whether g++ accepts -g... yes
> checking whether ln -s works... yes
> checking for iconv_open in -liconv... no
> checking for libiconv_open in -liconv... no
> checking for iconv_open in -lc... yes
> checking how to run the C preprocessor... gcc -E
> checking for grep that handles long lines and -e... /bin/grep
> checking for egrep... /bin/grep -E
> checking for ANSI C header files... yes
> checking for sys/types.h... yes
> checking for sys/stat.h... yes
> checking for stdlib.h... yes
> checking for string.h... yes
> checking for memory.h... yes
> checking for strings.h... yes
> checking for inttypes.h... yes
> checking for stdint.h... yes
> checking for unistd.h... yes
> checking iconv.h usability... yes
> checking iconv.h presence... yes
> checking for iconv.h... yes
> checking build system type... x86_64-unknown-linux-gnu
> checking host system type... x86_64-unknown-linux-gnu
> checking for pg_config... no
> configure: error: PostgreSQL is required by PostGIS
> make: *** [config.status] Error 1
> ¿que me esta faltando para poder instalar postgis?
> Z.M.
> postgis-users mailing list
"La buena educación, es lo que nos queda cuando se nos olvida todo lo que
nos han enseñado"
http://StrategicDecision.net/
+57 (2) 318 1000 ext. 2910
Cali - Colombia
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090227/5726cded/attachment.html>
