[postgis-users] Error using PostGIS and GEOM
Giri giriprakash at gmail.com
Fri Feb 27 16:48:27 PST 2009
Hi Mark,
I am using the latest stable versions of Geoserver and PostGIS, the
installation looks good, no errors were reported.
Thanks!
Giri
On Fri, Feb 27, 2009 at 10:11 AM, Mark Cave-Ayland <
mark.cave-ayland at siriusit.co.uk> wrote:
> Giri wrote:
>  Thanks for the response, mmm I am using Geoserver (version1.7.2) , and
>> when I try to create the featureType "polygon", it is complaining about
>> class org.postgresql.util.PSQLException: ERROR: function extent(geometry)
>> does not exist
>> shouldn't PostGIS  have some backword support for the extent function?
>> thanks!
>> Giri
> Hi Giri,
> There has been talk of removing the old non-ST prefix functions from
> PostGIS, but so far this hasn't happened. Perhaps you need to check your
> installation?
> HTH,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090227/9615c692/attachment.html>
