[postgis-users] help : postgis on a mac os x
Ben Madin ben at remoteinformation.com.au
Fri Feb 27 17:00:45 PST 2009
Youssef,
On 27/02/2009, at 5:01 AM, postgis-users-
request at postgis.refractions.net wrote:
> Date: Thu, 26 Feb 2009 16:03:38 +0000
> From: Youssef BEGHI <josefb at gmail.com>
> Subject: [postgis-users] help : postgis on a mac os x
> Message-ID:
> 	<b66713840902260803i225c2157i4237c53bd2e46bcf at mail.gmail.com>
> I'm not quite familiar with the GIS. I try to install postGIS in a
> mac os x
> (leopard) but it doesn't work when I performe the command :
> sudo su - postgres -c '/usr/local/pgsql/bin/psql -d [dbname] -f
> /usr/local/pgsql/share/lwpostgis.sql'
> with my dbname instead of [dbname]
> I recieve many error lines like these
> psql:/usr/local/pgsql/share/lwpostgis.sql:6500: ERROR: current
> transaction
> is aborted, commands ignored until end of
There is probably a permissions problem, but it will be in the first
few lines of output... after that every other command will fail, hence
the long output of errors.
So :
1. look back at the start of the error messages.
in the meantime,
2. did you do the createlang step?
3. Does [dbname] exisit?
4. if it is owned by you, just do it as you. (for simplicity)
5. make sure you have read permisssions on the file lwpostgis.sql
6. put /usr/local/pgsql/bin into your PATH, so you can just use
psql -d dbname -f /usr/local/pgsql/share/lwpostgis.sql
cheers
Ben
Ben Madin
REMOTE INFORMATION
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
							Out here, it pays to know...
