[postgis-users] Help with an area and hole filter query?
Simon Greener simon at spatialdbadvisor.com
Fri Jan 2 00:58:23 PST 2009
Regina,
> What I was thinking of was this.
> CREATE OR REPLACE FUNCTION upgis_filter_rings(geometry,float) RETURNS geometry AS
> $$ SELECT ST_BuildArea(ST_Collect(a.geom)) as final_geom
> 	FROM ST_DumpRings($1) AS a
>           WHERE a.path[1] = 0 OR
> 		(a.path[1] > 0 AND ST_Area(a.geom) > $2)
>   LANGUAGE 'sql' IMMUTABLE;
Oh, yes, very nice and concise.
> The main disadvantage aside from possibly speed over Simon's is that if you have 3-d polygons, I think the above will squash them to 2d where as his approach will support 3D.
That's an advantage I didn't realise about. (My experience with PostGIS functions is fairly beginner and there are a lot of functions to master.)
> On closer inspection -- when applying the above to the example polygon Simon provided the above returns a multipolygon and filter_rings returns a POLYGON and that is because if you  do a validity check of the polygon, its invalid because the holes lie outside of the exterior ring.  Buildarea just assumes everything outside is a polygon and everything inside is hole where as ST_MakePolygon takes your categorization of hole/vs shell as gospel.
A nice explanation.
> So better compare
> SELECT ST_AsText(upgis_filter_rings(ST_GeomFromText('POLYGON((10 10,10
> 20,20 20,20 10,10 10),(13 17, 13 14, 15 15.82, 13 17), (18 15, 18 14, 18 14, 18 15))')
> ,2));
> SELECT ST_AsText(filter_rings(ST_GeomFromText('POLYGON((10 10,10
> ,2));
> Which yield the same answer.
Yes, they do, I have tried them.
(I'll add this additional, excellent, work by Regina - if you don't mind - to my simple blog article on this filter_rings.)
> Hope that helps,
Well, I found it excellent!
regards
Simon
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
  Email: simon at spatialdbadvisor.com
  Voice: +613 9016 3910
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
