[postgis-users] Pgrouting directions
Ahmad Bdair
bdair2002 at gmail.com
Mon Jan 5 03:02:28 PST 2009
Thanx Steve, your information were helpful, but when I think of it it
confuses me a lot, lets first start with my fields in DB.
Columns are:
gid serial NOT NULL,
rod_name_a character varying(50),
label character varying(50),
rod_length integer,
rod_no integer,
rod_type character varying(1),
rod_class character varying(1),
rod_code character varying(10),
shape_leng numeric,
the_geom geometry,
source integer,
target integer,
length double precision,
x1 double precision,
y1 double precision,
x2 double precision,
y2 double precision,
to_cost double precision,
"rule" text,
cost_factor integer,
main_cost double precision,
reverse_cost double precision,
roadclass text DEFAULT 'OTHER'::text,
cost_reverse_factor integer DEFAULT 5,
Now, I am confused, because I cannot calculate the heading in the first
place, If I have
B+---\
x2,y2
x1,y1
A+---/
Now I can calculate the heading simply by comparing x1 and y1 to x2 to y2
and which is larger (based on lonlat) so I can judge it, but some times I am
having this:
B+---\
x1,y1
x2,y2
A+---/
Now it is misleading, maybe thats why you told me not to use start and end
point, but wait, what else to use ? According to my DB I cannot think of any
other way to calculate headings and angles.
Regards
On Wed, Dec 31, 2008 at 7:45 AM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> Ahmad Bdair wrote:
>> Yes, that is something very similar to what I need to do, I already wrote
>> a php code to check angels and slopes, but it was not accurate, it was more
>> life "if else" code, I check the longlat for current segment
> When you check the angles do not use the end points because they are
> mis-leading.
> B+---\
> A+---/
> If you have a segment from A to B like the above and you calculate the
> heading or angles based on the vector AB then it will point north and is
> should be pointing west at the end of the vector or east at the start of the
> vector.
> You also need to look at weather or not you need to flip segments because
> you route might traverse them from start to end OR from end to start.
> When I compute angles I grid the angles into 8 pie pieces of 45 degrees
> each.
> continue straight
> turn slight right/left
> turn right/left
> turn sharp right/left
> make a u-turn
> with longlat for the previous one, I guess you didn't use the database for
>> direction calculation(except for routing) am I right? Isn't steps 3 and 4
>> depends on your angel calculations?
> I have done this in C in a prototype router I wrote years ago. I have
> implemented it in PHP and in perl in various incarnations in the past. The
> demo page has it written in pgpsql, but it is based on my own heavily
> modified versions of the pgRouting stored procedures.
> Hope the above helps with your problems. I find it easiest to work out the
> math problems of computing the angles and headings first and make sure they
> are correct. Then move on to the other issues. If your math is wrong
> computing the headings and angles it will cloud all the other results.
> Best regards,
> -Steve
> I have the roads with two different languages, a road map like anyother
>> road map I guess.
>> On Tue, Dec 30, 2008 at 3:17 AM, Stephen Woodbridge <
>> woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>> bdair2002 wrote:
>> Hello,
>> I am developing an application using Pgrouting with Postgis
>> data, everything
>> is fine, but now I am looking to do something like Google
>> directions guide,
>> where it tells you turn left or right, I am wondering if this
>> feature is a
>> built-in feature in Pgrouting or Postgis.
>> Regards
>> No this is not a feature that is part of either.
>> I have implemented a directions explicator, but it is somewhat
>> specific to the data that you have, as you need to know what
>> column(s) contain the road names, if you have signage information
>> then you need to know how to link to that. If you want to be able to
>> explicate in multiple languages, then you probably need to consider
>> supporting multiple languages each in a separate table the you can
>> select from when you generate the languages.
>> The algorithm is pretty straight forward as the you currently get a
>> list of segments that make up the route. Then you need to:
>> analyze each segment and
>> 1) check to see if you want to join it with the previous segment
>> because the road name matches
>> 2) check the angle that it makes with the last segment to determine
>> right, left, straightness of turn
>> 3) compute the compass heading for the segment
>> 4) determine if you have signage
>> 5) based on these, determine if you are read to explicate and which
>> predefined instruction you need to explicate an instruction
>> 6) loop through all segments
>> For a demo of this you can try:
>> http://imaptools.com/leaddog/routing/dd.html
>> Zoom into a city in one of the yellow areas, set a start and end
>> point and click [calculate route] button. The driving directions
>> should show below the button if it was successful, be patience the
>> routing is running on a 333MHz box.
>> -Steve
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090105/19ff02a2/attachment.html>
