[postgis-users] Strange behaviour with st_difference
Mike Leahy mgleahy at alumni.uwaterloo.ca
Tue Jan 13 00:04:41 PST 2009
Hello list,
I'm having a problem with st_difference, where two overlapping
geometries will return an empty geometrycollection, as if the do not
overlap.  However, if I use st_difference on the same geometries, but
converted to EWKT, then back, then using st_difference yields the
expected output.  Basically, this is what I'm getting (minus the output
coords):
# select st_astext(st_difference(g1,g2)),
st_astext(st_difference(st_asewkt(g1),st_asewkt(g2))) from temp;
         st_astext         |  st_astext
  GEOMETRYCOLLECTION EMPTY | POLYGON(( .... ))
(1 row)
The resulting (correct) polygon is very small (a total area of
0.00048828125, using UTM coordinates), so maybe there's a problem with
that?  The result of st_overlaps(g1,g2) is true for the same data that
cause this problem.
I could email someone the geometries if that would help.
Regards,
Mike
