[postgis-users] Strange behaviour with st_difference
Mike Leahy
mgleahy at alumni.uwaterloo.ca
Tue Jan 13 01:41:04 PST 2009
Mark Cave-Ayland wrote:
> Mike Leahy wrote:
>> Hello list,
>> I'm having a problem with st_difference, where two overlapping
>> geometries will return an empty geometrycollection, as if the do not
>> overlap. However, if I use st_difference on the same geometries, but
>> converted to EWKT, then back, then using st_difference yields the
>> expected output. Basically, this is what I'm getting (minus the
>> output coords):
>> # select st_astext(st_difference(g1,g2)),
>> st_astext(st_difference(st_asewkt(g1),st_asewkt(g2))) from temp;
>> st_astext | st_astext
>> GEOMETRYCOLLECTION EMPTY | POLYGON(( .... ))
>> (1 row)
>> The resulting (correct) polygon is very small (a total area of
>> 0.00048828125, using UTM coordinates), so maybe there's a problem with
>> that? The result of st_overlaps(g1,g2) is true for the same data that
>> cause this problem.
>> I could email someone the geometries if that would help.
>> Regards,
>> Mike
> Hi Mike,
> I think you'll have to post the geometries if you want someone to help
> you. If they are large then place them in a text file and send it to the
> list as a zipped/gzipped attachment.
> Oh, and don't forget the output of "SELECT postgis_full_version()" while
> you're at it :)
> ATB,
> Mark.
Here they are attached - both as text and as binary within an sql
statement that replicates the results of the example describe above.
postgis_full_version (from the yum repo on Fedora 10, x86_64):
POSTGIS="1.3.5" GEOS="3.0.3-CAPI-1.4.2" PROJ="Rel. 4.6.1, 21 August
2008" USE_STATS
Type: application/x-gzip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090113/d75f9af9/attachment.bin>
