[postgis-users] Fixing invalid polygons created from polygonizing rasters
Martin Davis
mbdavis at refractions.net
Wed Jan 14 11:04:36 PST 2009
You can try using buffer(0) on the geometry - this often fixes this kind
of problem.
William Temperley wrote:
> Hi all,
> We have some polygonized rasters that create invalid GEOS geometries.
> Take polygon A I've attempted to illustrate below. It is one ring,
> which touches itself at a single point. In line with the OGC spec it
> is invalid. If it becomes two polygons, it is valid (See B I've
> illustrated below).
> It would be great if anyone knew of an algorithm to make A into B.
> Thanks
> Will
> A
> ____
> | __|___
> | |__| |
> |_______|
> MAP=# select isvalid(geomfromtext('MULTIPOLYGON(((0 0, 0 3, 2 3, 2 2,
> 1 2, 1 1, 2 1, 2 2, 3 2, 3 0, 0 0)))')
> NOTICE: Ring Self-intersection
> isvalid
> f
> B
> ____
> | 1__|___
> |__|__| |
> |______2|
> MAP=# select isvalid(geomfromtext('MULTIPOLYGON(((0 0, 0 1, 2 1, 2 2,
> 3 2, 3 0, 0 0)),((0 1, 0 3, 2 3, 2 2, 1 2, 0 1)))')
> isvalid
> t
> (1 row)
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
