[postgis-users] Mapinfo
    Obe, Regina
    robe.dnd at cityofboston.gov
    Fri Jan 16 06:53:11 PST 2009
I just had someone here who has MapInfo 8.5 check.  I see it has both
WMS and WFS.  He said he'd give it a try later on today or Monday.  I am
curious to see how it handles WFS services.   the WMS from what I recall
was pretty decent, but you can't really get data aside form getinfo from
WMS calls.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Obe,
Regina
Sent: Friday, January 16, 2009 9:00 AM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Mapinfo
Oh yes I forgot the WMS WFS route.  In older versions of MapInfo I think
like MapInfo 7 -  I was able to use a WMS UMN mapserver connection.
In later versions of Map Info I think they introduced WFS, but I have
yet to try that out.
James Stott
Sent: Friday, January 16, 2009 3:40 AM
If you want to see spatial data from PostGIS in MapInfo 'directly' from
PostGIS, the only way to do this is to use FME. As stated earlier, it is
read only though.
If you just want to use attribute data then you can access that using a
DBMS connection, but I am guessing you want the spatial data.
One other way which I have heard suggested is to use WMS or WFS to get
your data into MapInfo from PostGIS.
More and more GIS packages are supporting PostGIS so hopefully it will
just be a matter of time before MapInfo adds support.
Stephen Carville
Sent: 15 January 2009 22:36
To: PostGIS Users
Subject: [postgis-users] Mapinfo
Are Mapinfo and PostGIS compatible?   I've seen a few messages on
MapInfo-L
that sorta imply they work together.  Maybe.  But there is no support
mentioned on the MapInfo website.
Stephen Carville <scarville at landam.com>
Systems Engineer
Land America
1.626.667.1450 X1326
Any security software design that doesn't assume the enemy
possesses the source code is already untrustworthy.
                                           -- Eric Raymond
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
This Electronic Transmission is intended only for the attention of the
addressee. It may contain privileged and confidential information. If
you are not the person for whom it is intended, you must not copy,
distribute or take any action in reliance on it. If you have received
this electronic transmission in error please notify us immediately by
telephone, delete the transmission and destroy any hard copies.
Nicholas Pearson Associates has used all reasonable efforts to ensure
that this message and any attachments are free from viruses.
Environmental Planners - Landscape Architects - Ecologists
30 Brock Street, Bath, BA1 2LN
Tel: +44 (0) 1225 445548, Fax: +44 (0) 1225 312387
http://www.npaconsult.co.uk/
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
