[postgis-users] transform params
Paragon Corporation
lr at pcorp.us
Mon Jan 19 11:00:12 PST 2009
Might have to do with the proj version you are using adnthe nad shift grid
thingy.
What does
SELECT postgis_full_version();
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of toni
hernández
Sent: Monday, January 19, 2009 10:50 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] transform params
hi,
I have a postgis table with the srid=23031.
If I overlay this table with a WMS on some sofware (gvSIG; ArcGIS),
everything fits perfectly but when I transform the postgis table to
23030 and try the overlay to the same WMS (configuring now the WMS to
work with epsg=23030) the overlay does not fit anymore. There is a
difference of 70 metres difference (give or take)
And whats more.. if I export my postgis table to a shp file and then use
the shp file to transform the coordinates from ArcGIS (again from 23031
to 23030) the overlay with the same WMS fits again.
So I guess postgis is not doing the transformation as I need.
I thinks I have to change some params in the spatial_ref_sys table but
have no idea what these parameters are.
This is what the spatial_ref_sys for srid=23030 looks like:
srText field:
PROJCS["ED50 / UTM zone
30N",GEOGCS["ED50",DATUM["European_Datum_1950",SPHEROID["International
1924",6378388,297,AUTHORITY["EPSG","7022"]],AUTHORITY["EPSG","6230"]],PRIMEM
["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,A
UTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4230"]],PROJECTION["Transverse_Me
rcator"],PARAMETER["latitude_of_origin",0],PARAMETER["central_meridian",-3],
PARAMETER["scale_factor",0.9996],PARAMETER["false_easting",500000],PARAMETER
["false_northing",0],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AUTHORITY["EPS
G","23030"]]
proj4Text:
+proj=utm +zone=30 +ellps=intl +units=m +no_defs
From ArcGIS I have this OUTPUT properties after the transformation:
PROJCS['ED_1950_UTM_Zone_30N',GEOGCS['GCS_European_1950',DATUM['D_European_1
950',SPHEROID['International_1924',6378388.0,297.0]],PRIMEM['Greenwich',0.0]
,UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAME
TER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Cen
tral_Meridian',-3.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of
_Origin',0.0],UNIT['Meter',1.0]]
Anyone can help?
thanks in advance.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
