[postgis-users] negative buffer
Torsten Lange tlange at gwdg.de
Tue Jan 20 12:10:47 PST 2009
Hello!
I have polygons with sometimes very peculiar shapes representing the
distribution limits of specific types of sediments (e.g. channel-like
branching, fluvial fans...). When I try to create positive and negative
buffers of that polygons using the combined
(st_buffer(st_simply(geom,i)j)-method I succeed only in positive
direction. In negative direction it very fastly violates
enforce_geotype_geom-check. When I look on the last results I see, it is
related to the channel-like branches. Using the buffer-method in ArcGIS
it works as expected. Is there a clever method getting it work in
PostGIS too?
Thank you, Torsten
