[postgis-users] negative buffer
Torsten Lange
tlange at gwdg.de
Wed Jan 21 03:12:11 PST 2009
Vincent, thank you for the suggestion!
The problem seems to be solved now! I googled a bit because not knowing
what st_buffer(geom,0) really does and by the way found a former
problem. This was solved by additionally dropping the
enforce_geotype_geom-check constraint, which enabled
st_buffer(st_buffer(geom,-i)0) to perform the job as expected - very nice!
So 3 question remain:
What does st_buffer(geom,0) - just optimising the segments of the polygone?
Before I dropped the constraint it prevented the insert of the buffer
geometry because it complained to be violated. Dropping it
st_isvalid()however gives TRUE. This is a bit confusing to me. Do I mix
something here? And are invalid geometries now likely to produced by
postgis functions in some cases due to dropping the geometry check?
Thank you, Torsten
>>I have polygons with sometimes very peculiar shapes
>>representing the distribution limits of specific types of
>>sediments (e.g. channel-like branching, fluvial fans...).
>>When I try to create positive and negative buffers of that
>>polygons using the combined
>>(st_buffer(st_simply(geom,i)j)-method I succeed only in
>>positive direction. In negative direction it very fastly
>>violates enforce_geotype_geom-check. When I look on the last
>>results I see, it is related to the channel-like branches.
>>Using the buffer-method in ArcGIS it works as expected. Is
>>there a clever method getting it work in PostGIS too?
>As for getting negative buffers to be valid geometries, I generally use
>the 0-buffer trick as in :
>st_buffer(st_buffer(geom, -i), 0). Not 100% sure it will work but it
>generally fixes a lot of problems.
>Let us know of the results if you try that with your data.
>Vincent
