[postgis-users] Call for Semantics (ST_CollectionTypes())
Chris Hermansen
chris.hermansen at timberline.ca
Wed Jan 28 17:34:53 PST 2009
As someone accustomed to doing my geoprocessing in ArcInfo, one of the
first things I was looking for in PostGIS was the ability to do:
INTERSECT conserv_area forest cons_for POLY 1.0 NOJOIN
I guess I probably naively tried something like:
CREATE TABLE cons_for AS
SELECT
conserv_area_id,
forest_id,
st_intersection(conservation_areas, forest) the_geom
FROM conservation_areas, forest
At that point, I must have wondered about what exactly that stuff was in
the_geom in the new table
Maybe it's not too much of a stretch to wish for
SELECT
st_just_gimme_the_polygons(st_intersection(conservation_areas,forest))
Paul Ramsey wrote:
> Well, right now, how do I turn a column of MULTIPOLYGON goemetries
> into a single collected MULTIPOLYGON? I have to rather inefficiently
> explode them, then re-collect them. Kind of a trivial example.
> More fiddly for people to currently solve, the ST_Intersection()
> function can spit out heterogeneous GEOMETRYCOLLETIONS as a result.
> And usually, the end-user just wants one component of that... if
> intersecting lines on polygons, they just want lines, and don't care
> about any points. Or if doing poly-on-poly, they don't care about any
> lines or points that fall out the bottom, as occasionally happens.
> P.
> On Wed, Jan 28, 2009 at 4:40 PM, Mark Cave-Ayland
> <mark.cave-ayland at siriusit.co.uk> wrote:
>> Paul Ramsey wrote:
>>> I would like to add a function that takes an anonymous
>>> GEOMETRYCOLLECTION and returns something more structured:
>>> - a GEOMETRYCOLLECTION where the first element is a MULTLIPOLYGON, the
>>> second a MULTILINESTRING and the third a MULTIPOINT?
>>> - a tuple, with elements 'polygons', 'linestrings', 'points', each
>>> with one multi* of each?
>>> - a tuple, with elements 'polygons', 'linestrings', 'point', each with
>>> an array of singletons?
>>> The key here is to provide a useful flat structure to pull info out
>>> of. Some information in the GEOMETRYCOLLECTION *will be lost*, (but
>>> that seems an acceptable price)
>>> Another approach, which might be simpler for users to grok would be:
>>> ST_CollectionAsMultiPolygon() returns just the polygon elements of a
>>> collection.
>>> ... etc ...
>>> Thoughts?
>>> P.
>> Hi Paul,
>> I'm still struggling to get an idea of exactly what these proposed functions
>> are trying to achieve. Can you show some potential problems/SQL statements
>> showing how you would envisage these functions being used?
>> ATB,
>> Mark.
>> Mark Cave-Ayland
>> Sirius Corporation - The Open Source Experts
>> http://www.siriusit.co.uk
>> T: +44 870 608 0063
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Chris Hermansen mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
