[postgis-users] portable spatial db
Paul Ramsey
pramsey at opengeo.org
Fri Jan 30 08:56:44 PST 2009
If the versions are the same, you should be able to move the instance
from place to place (note, I say "instance" not database, instances
are the collections of databases that reside in one data area)
initdb on your SATA
start your pgsql, with -D to your SATA
load your data
stop your pgsql
remove your SATA
plug it into new machine
start pgsql with -D to your SATA
play
On Fri, Jan 30, 2009 at 8:46 AM, Clay, Bruce <bclay at ball.com> wrote:
> If I build a spatial database on a removable ESATA disk drive, is there a
> way to use the DB on a different computer with the same version of postgis?
> Bruce
> This message and any enclosures are intended only for the addressee. Please
> notify the sender by email if you are not the intended recipient. If you
> are
> not the intended recipient, you may not use, copy, disclose, or distribute
> this
> message or its contents or enclosures to any other person and any such
> actions
> may be unlawful. Ball reserves the right to monitor and review all messages
> and enclosures sent to or from this email address.
> postgis-users mailing list
