[postgis-users] portable spatial db
Obe, Regina
robe.dnd at cityofboston.gov
Fri Jan 30 09:23:13 PST 2009
Bruce,
Have you taken a look at PortableGIS? It has a USB version of
PostgreSQL with a bunch of other popular Open Source GIS tools.
Might be ideal for what you are doing.
Though I think its only windows version.
http://www.archaeogeek.com/blog/portable-gis/
hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, January 30, 2009 12:16 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] portable spatial db
Yes, each port maps to an instance (a running copy of pgsql), and an
instance contains many databases. You've got it.
P
On Fri, Jan 30, 2009 at 9:08 AM, Clay, Bruce <bclay at ball.com> wrote:
> Thanks Paul, I will try that although I have to admit I am more of a
GIS
> coder than a DB coder so I will have to start the process to
understand
> the significance of "instance" in this case. I know when I connect to
> Oracle through GDAL or ArcGis it is the port number. I assume it is
the
> same for PG.
> Thanks again.
> Bruce
Paul
> Ramsey
> Sent: Friday, January 30, 2009 11:57 AM
> If the versions are the same, you should be able to move the instance
> from place to place (note, I say "instance" not database, instances
> are the collections of databases that reside in one data area)
> initdb on your SATA
> start your pgsql, with -D to your SATA
> load your data
> stop your pgsql
> remove your SATA
> plug it into new machine
> start pgsql with -D to your SATA
> play
> On Fri, Jan 30, 2009 at 8:46 AM, Clay, Bruce <bclay at ball.com> wrote:
>> If I build a spatial database on a removable ESATA disk drive, is
> there a
>> way to use the DB on a different computer with the same version of
> postgis?
>> Bruce
>> This message and any enclosures are intended only for the addressee.
> Please
>> notify the sender by email if you are not the intended recipient. If
> you
>> are
>> not the intended recipient, you may not use, copy, disclose, or
> distribute
>> this
>> message or its contents or enclosures to any other person and any
such
>> actions
>> may be unlawful. Ball reserves the right to monitor and review all
> messages
>> and enclosures sent to or from this email address.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Please
you are
distribute this
> message or its contents or enclosures to any other person and any such
actions
messages
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
