[postgis-users] 3D Topology
francesco
francesco.pirotti at unipd.it
Fri Jan 2 01:46:22 PST 2009
Following the question on 3D I was wondering if the 3D support in postgis includes importing/exporting PolygonZ PolylineZ and PointZ from shapefiles thus saving the z component in vertices!
Cheers
Francesco Pirotti
Dept. Te.S.A.F./CIRGEO
University of Padua
Viale dell'Università 16
I-35020 Legnaro (PD)
tel. +39 049 827 2710
fax. +39 049 827 2686
mob. +39 349 55 39 261
@mail francesco.pirotti at unipd.it
skypeID francesco197576
http://www.cirgeo.unipd.it/cirgeo/francescopirotti.htm
---------- Original Message ----------
To: PostGIS Users Discussion (postgis-users at postgis.refractions.net)
Subject: RE: [postgis-users] 3D Topology
Date: 2/1/2009 5:16:10
Depends what you are trying to do. PostGIS has very primitive support for 3D.
1) 3D volumetric objects are not supported
2) 3D non-volume are supported partly -- e.g. a 2D polygon in 3 d space, a line, point in 3d space.
3) Spatial relationships however only really consider the spatial component of the x, y plane.
There is work in that area - for example
http://www..foss4g2007.org/presentations/view.php/224
And work is going on in general to expand the PostGIS underlying geometry structure to support more types
such as some missing curve support types and in future TIN and so forth.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net on behalf of Brian Sanjeewa Rupasinghe
Sent: Thu 1/1/2009 9:30 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] 3D Topology
My question is: Does PostGIS support 3D topology?
The substance of this message, including any attachments, may be confidential, legally privileged and/or exempt from disclosure pursuant to Massachusetts law. It is intended solely for the addressee. If you received this in error, please contact the sender and delete the material from any computer.
Help make the earth a greener place. If at all possible resist printing this email and join us in saving paper.
