[postgis-users] large table question
Suhr, Ralf Ralf.Suhr at itc-halle.de
Thu Jul 2 00:02:29 PDT 2009
Your DB-design depend on your application. Storing only the points plus 2-3 attributes will going into one table.
To make your db faster, there are many possibilitys:
  - compound points with/without M-values
  - create child-tables with the inherits-postgres-feature
  - create child-tables with check-constraints, triggers and put them together with a view
Creating child-tables will slow down extremly write performance, but on reading the db has not to read the hole index because the check-constraints. And you can put your tables on different tablespaces.
Ralf
	-----Ursprüngliche Nachricht-----
	Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von Clay, Bruce
	Gesendet: Mittwoch, 1. Juli 2009 19:13
	An: postgis-users at postgis.refractions.net
	Betreff: [postgis-users] large table question
	We are looking into Postgres/PostGis as a possible alternative to Oracle for one of our projects.  Some of our data tables have over 800 million data points.
	Has anyone tried to put that much data into a single data table?
	Does anyone have any advice on tuning Postgres/PostGis to be able to handle large datasets?
	Bruce
	This message and any enclosures are intended only for the addressee.  Please
	notify the sender by email if you are not the intended recipient.  If you are
	not the intended recipient, you may not use, copy, disclose, or distribute this
	message or its contents or enclosures to any other person and any such actions
	may be unlawful.  Ball reserves the right to monitor and review all messages
	and enclosures sent to or from this email address.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090702/ea4578f7/attachment.html>
