[postgis-users] Polygon and Multipolygon distinguished by fieldtype constraint - call for a generic AnyPoly type
Ben Harper
rogojin at gmail.com
Thu Jul 2 04:55:25 PDT 2009
Thanks - I'll give that a try.
On Thu, Jul 2, 2009 at 1:17 PM, Suhr, Ralf<Ralf.Suhr at itc-halle.de> wrote:
> You need two things:
> 1) change the geom constraint
> ALTER TABLE YOUR_TABLE DROP CONSTRAINT enforce_geotype_geom;
> ALTER TABLE YOUR_TABLE ADD CONSTRAINT enforce_geotype_geom CHECK (geometrytype(geom) = 'POLYGON'::text OR geometrytype(geom) = 'MULTIPOLYGON'::text OR geom IS NULL);
> 2) Create a trigger with ST_Multi(NEW.geom) for your table
> Be aware, that some functions don't working directly with Multigeometrys.
> Ralf
> -----Ursprüngliche Nachricht-----
> Von: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] Im Auftrag von Ben Harper
> Gesendet: Donnerstag, 2. Juli 2009 12:47
> An: postgis-users at postgis.refractions.net
> Betreff: [postgis-users] Polygon and Multipolygon distinguished by fieldtype constraint - call for a generic AnyPoly type
> I am looking for a way of creating a geometry field that has a constrained type identical to the Shapefile spec. Basically, Polygons and MultiPolygons are equals. Linestrings and Multilinestrings are equals. Is there a way to accomplish this with PostGIS? If I make the field Polygon, then I can't insert Multipolygons, and vice versa.
> Thanks,
> Ben
> postgis-users mailing list postgis-users at postgis.refractions.net
