[postgis-users] Z and M coordinates seem inconsistent and barely supported
Ben Harper
rogojin at gmail.com
Thu Jul 2 13:31:55 PDT 2009
Thanks - I see that EWKT works, but is there an equivalent mechanism for WKB?
SELECT AsBinary(GeomFromEWKT('POINT(0 0 0 0)'));
yield the exact same result as
SELECT AsBinary(GeomFromEWKT('POINT(0 0)'));
On Thu, Jul 2, 2009 at 5:56 PM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
> select geomfromewkt('POINT(0 0 0 0)');
> On Thu, Jul 2, 2009 at 8:51 AM, Ben Harper<rogojin at gmail.com> wrote:
>> I'm struggling to create a geometry field in PostGIS that stores Z and
>> M coordinates. Are these supported?
>> Some issues:
>> 1. I cannot create a ZM field. "Dimensionality must be 3 or less"
>> 2. GeomFromText() doesn't recognize "POINT Z (0 0 0)"
>> 3. GeomFromText() does parse (with a warning) "POINTM (0 0 0)", but it
>> appears the DB isn't really storing the Z coordinate.
>> 4. Using the C library interface, I can't get WKB geometry with Z to parse.
>> Thanks,
>> Ben
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
