[postgis-users] Polygon and Multipolygon distinguished by field type constraint - call for a generic AnyPoly type
Ben Harper
rogojin at gmail.com
Thu Jul 2 22:31:58 PDT 2009
The reason I don't want to use a GEOMETRY type is because the rest of
my application stack is built to work with Shapefile-style homogeneous
geometry fields.
The alteration of the constraint, with Ralf suggested, works fine for
my purposes. It's not particularly interoperable, but that is fine for
me right now. I guess it is actually equivalent to creating the field
with a GEOMETRY type, and then simply altering the geometry_columns
table so that it is 'POLYGON', or whatever the case may be.
Ben
On Thu, Jul 2, 2009 at 4:21 PM, Ben Madin<ben at remoteinformation.com.au> wrote:
> Could you not just use a Geometry type?
> cheers
> Ben
> On 02/07/2009, at 5:47 PM, Ben Harper wrote:
>> I am looking for a way of creating a geometry field that has a
>> constrained type identical to the Shapefile spec.
>> Basically, Polygons and MultiPolygons are equals. Linestrings and
>> Multilinestrings are equals.
>> Is there a way to accomplish this with PostGIS?
>> If I make the field Polygon, then I can't insert Multipolygons, and vice
>> versa.
>> Thanks,
>> Ben
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Ben Madin
> REMOTE INFORMATION
> t : +61 8 9192 5455
> f : +61 8 9192 5535
> m : 0448 887 220
> Broome WA 6725
> Out here, it pays to
> know...
