[postgis-users] Can't QGIS see GRASS tables in PostGIS??
Thybério Luna Freire
thyberio at gmail.com
Sun Jul 5 13:31:43 PDT 2009
Solved!!!
I changed the way to import shapefiles. Before, i imported into GRASS and
saved in PostGIS table. Now i import into PostGIS using shp2pgsql and then i
import it to GRASS. How GRASS create a new table, a delete this new table
and connect the vector layer with the original table. In this way, GRASS,
PostGIS and QGIS can talk themselves. It seems complicated, but woks.
Thanks!!!
Thybério Luna
2009/7/4 thyberio <thyberio at gmail.com>
Hi all,
I have a GRASS location with driver=pg. When i save a new vector GRASS
layer
in a PostGIS table, it can't be seen by QGIS through "add postgis
layer". In
this way i can't see views created from this table too. I noted that the
column the_geom doesn't appear in the table. Is that the problem? Don't
they
have compatibility?
I'm using:
Ubuntu 9.04 - GRASS64 - PostgreSQL 8.3 - PostGIS 1.3.3-3 - QGIS 1.1
Help meeeee!!!!
Thybério Luna - Brazil
View this message in context:
http://www.nabble.com/Can%27t-QGIS-see-GRASS-tables-in-PostGIS---tp24339709p24339709.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090705/44e8c73c/attachment.html>
