[postgis-users] Postgis - Line to Point distance
Pedro Doria Meunier
pdoria at netmadeira.com
Fri Jul 10 01:35:15 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi Peter
You could use the pointn(geometry, n) for the first point of the
linestring as a first approach.
As far as meters are concerned here's a little example of transforming
the geometry to the desired projected system:
select distance(transform(u.coordinates,srid),
transform(p.geometry,srid)) AS thedistance
HTH,
Pedro Doria Meunier
GSM: +351 96 17 20 188
Skype: pdoriam
Peter Kukuča wrote:
> Dear sir,
> I am not sure if I am writing to the correct email address. I have
> found a post on the postgis-users formu from *Rich Gibson *and this
> address was next to it.
> I am using postgis for a while now and it is great. It solved a lot
> of problems for me.
> However, I am now facing a problem I cannot solve. I searched for
> almost two days now, but I still cannot find an answer. Here is my
> problem:
> I have a database of linestrings in wgs84 projection and points in
> wgs84 projection. I would like to determine the distance between a
> line and a point. The ST_distance function does this very well, but
> it does not take the wgs84 projection into account and also, the
> result is in degrees. On the other hand, the ST_Distance_Spheroid
> does take the wgs84 into accound and does give the result in meters,
> but it does not accept a linestring as an input parameter.
> Is there any way i can the distance between a line and a point in
> meters from the wgs84 projected input? I do not need grat accuracy.
> +-5 meters is still good enough. Thank you for your tips.
> S pozdravom (regards)
> Ing. Peter Kukuča
> postgis-users mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
iD8DBQFKVv052FH5GXCfxAsRAqS1AJ0dfphFX3wrMuo+FdXVRTgmUzHRUACfUmvH
146yGHfxoVmlnt9a91rpWmE=
=G70f
-----END PGP SIGNATURE-----
