[postgis-users] Postgis - Line to Point distance
Pedro Doria Meunier
pdoria at netmadeira.com
Fri Jul 10 01:53:10 PDT 2009
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
You can always get the desired SRID from the spatial_ref_sys table via
the longitude of your point.
Here's two helper functions in PHP to achieve just that:
// determine UTM zone from LonLat coordinates
// params $long: longitude
// returns (int) utm
function UtmZoneFromLong($lon) {
$utm = floor(($lon + 180) / 6) + 1;
return $utm;
// query the spatial_ref_sys table for the srid of the given utm zone
// params $utm: utm zone string (MUST BE TRAILED WITH 'N' OR 'S'!),
$conn: connection to the db
// returns (int) srid
function SridFromUtmZone($utm, $conn){
$myresult = pg_exec($conn, "SELECT srid FROM spatial_ref_sys WHERE
srtext LIKE 'PROJCS[\"WGS 84 / UTM zone $utm%' LIMIT 1");
$srid=pg_result($myresult, 0, 0);
return $srid;
Even if you're not in PHP programming I think that with this you can
extrapolate to some other solution ;-)
Pedro Doria Meunier
GSM: +351 96 17 20 188
Skype: pdoriam
Peter Kukuča wrote:
> Hi Pedro,
> thank you for your reply.
> I cannot use pointn, the line can be up to several hundred
> kilometers long and consits of up to 800 points, so this would be
> too rough.
> Regardinf the decond suggestion, that is exactly what I am doing
> now, but I don't know, which projection (srid) to transform the
> wgs84 data into. It should work on all of the earth's surface, at
> least in all of europe for a start. And from what I found, the
> projections are usually tied to a small territory. I was thinking
> about mercator projection, but there is a zillion of them in
> postgis. And I found a post, that the one with srid 900913 is
> working great, but I don't have that one in my postgis.
> 2009/7/10 Pedro Doria Meunier <pdoria at netmadeira.com
> <mailto:pdoria at netmadeira.com>>
> Hi Peter
> You could use the pointn(geometry, n) for the first point of the
> linestring as a first approach. As far as meters are concerned
> here's a little example of transforming the geometry to the desired
> projected system:
> select distance(transform(u.coordinates,srid),
> transform(p.geometry,srid)) AS thedistance
> HTH,
> Pedro Doria Meunier GSM: +351 96 17 20 188 Skype: pdoriam
> Peter Kuku a wrote:
>> Dear sir,
>> I am not sure if I am writing to the correct email address. I
>> have found a post on the postgis-users formu from *Rich Gibson
>> *and
> this
>> address was next to it.
>> I am using postgis for a while now and it is great. It solved
> a lot
>> of problems for me.
>> However, I am now facing a problem I cannot solve. I searched for
>> almost two days now, but I still cannot find an answer. Here is
>> my problem:
>> I have a database of linestrings in wgs84 projection and points
>> in wgs84 projection. I would like to determine the distance
>> between a line and a point. The ST_distance function does this
>> very
> well, but
>> it does not take the wgs84 projection into account and also, the
>> result is in degrees. On the other hand, the ST_Distance_Spheroid
>> does take the wgs84 into accound and does give the result in
> meters,
>> but it does not accept a linestring as an input parameter.
>> Is there any way i can the distance between a line and a point in
>> meters from the wgs84 projected input? I do not need grat
> accuracy.
>> +-5 meters is still good enough. Thank you for your tips.
>> -- S pozdravom (regards) Ing. Peter Kuku a
>> _______________________________________________ postgis-users
>> mailing list postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
postgis-users mailing list
> -- S pozdravom (regards) Ing. Peter Kukuča
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.7 (GNU/Linux)
Comment: Using GnuPG with Fedora - http://enigmail.mozdev.org
iD4DBQFKVwFs2FH5GXCfxAsRAgzVAKCUE0IUvsWUoyCtLqkRSzMKyzaq0QCY6EM2
QCdiM4Xn3ml5J/6aPRBLNA==
=VeCn
-----END PGP SIGNATURE-----
