[postgis-users] Postgis - Line to Point distance
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jul 10 07:21:20 PDT 2009
Peter Kukuča wrote:
> What is done in the example is a calculation of the distance represented
> by 1 degree of longitude at two different latitudes. While the distance
> at zero latitude is correct, the distance at 60° latitude should be
> exactly half that. The funny part is, that I get the same result with
> simple point to point calculations. And the absolutely best part is,
> when I swap all latitudes and longitudes, it works. Now the only
> reasonable explanation is, that all of the functions take longitude as
> their first parameter and latitude as the second, but isn't this the
> other way around?
Nope. PostGIS uses the computer standard of X followed by Y. Hence for
"POINT(X Y)", X is longitude (or eastings) and Y is latitude (or
northings). This is true for all PostGIS functions, and I believe is the
same for all spatial databases too.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
