[postgis-users] PostGIS-PostgreSQL
Paul Ramsey
pramsey at cleverelephant.ca
Mon Jul 13 08:30:00 PDT 2009
It's not the end of the world to have two geocolumns. From a practical
perspective, there will be a few apps that have a harder time making
sense of your tables, due to a one-spatial-column assumption. There's
not a bit storage implication to storing two points instead of one.
Note that, from a performance PoV, the cost of the re-projection is
really very small, so as an optimization it probably isn't a
world-beating thing. However, for things like measuring distances and
so on, the convenience of maintaining that projected column is
probably well worth it.
P.
On Mon, Jul 13, 2009 at 8:17 AM, Peter N.
Schweitzer<pschweitzer at usgs.gov> wrote:
> Chris Hermansen wrote:
>> I should have mentioned that it's not considered good practice to
>> have more than one geometry column per table, and hence more than
>> one geometry object per row. This makes sense if you think of rows
>> as representational instances of real world objects.
> Hmmm. I'm storing two geometry columns, because in one I have the
> geographic (unprojected) coordinates, and in the other the coordinates
> in some projection. This is to support several different map interfaces
> some of which are projected, others not. Since the points don't change
> frequently, I can generate the projected coords once and then simply
> use them rather than recalculate them on every web hit. It's denormalized,
> but seems sensible to me. Would you disagree with this method?
> Peter
> Peter N. Schweitzer (MS 954, U.S. Geological Survey, Reston, VA 20192)
> (703) 648-6533 FAX: (703) 648-6252 email: pschweitzer at usgs.gov
> <http://geology.usgs.gov/peter/>
> postgis-users mailing list
