[postgis-users] Creating a new table with geometry with differentnumber of rows from another table: how to do this
Paragon Corporation lr at pcorp.us
Wed Jul 15 12:53:19 PDT 2009
Matthew,
You want to create the table first
something like
CREATE TABLE shp_mcd_centroid(gid SERIAL PRIMARY KEY, mcd_name varchar(100),
type varchar(100));
then do the
SELECT AddGeometryColumn ....
(http://postgis.refractions.net/documentation/manual-1.4.0SVN/AddGeometryCol
umn.html  - which will both register and create the geometry column)
Then do
INSERT INTO shp_mcd_centroids(mcd_name, type, the_geom)
SELECT DISTINCT
    mcd_name,
    "type",
    Centroid( Collect ( the_geom ) ) as the_geom
FROM
    shp_mcd
GROUP BY
    mcd_name,
    "type"
Leo
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Matthew
Pettis
Sent: Wednesday, July 15, 2009 3:29 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Creating a new table with geometry with
I'm trying to find the right incantation on how to create a new table with a
geometry column from an old one efficiently.  Here's the essential query I
want to do...
CREATE TABLE shp_mcd_centroids AS
SELECT DISTINCT
    mcd_name,
    "type",
FROM
    shp_mcd
GROUP BY
    mcd_name,
    "type"
the_geom in shp_mcd is of type MULTIPOLYGON.  The_geom in shp_mcd_centroids
will be of type POINT or MULTIPOINT (I'm not sure which, an not sure how to
tell).  What I am missing is that I want to use AddGeometryColumn() to
register the new the_geom column in the geometry_columns table, and I want
to add a 'gid' column that is just an incremental integer as a PK on this
table, just like shp2pgsql created in my other tables.  I just can't seem to
get the right combination of SQL statements to do this.
Below is my (best) attempt with the results as well.  Any help is
appreciated.
Thanks,
Matt
Code
create table shp_mcd_centroids (
    gid serial PRIMARY KEY,
    mcd_name character varying(10),
    "type" character varying(14)
SELECT
AddGeometryColumn('public','shp_mcd_centroids','the_geom','26915','MULTIPOIN
T',1);
INSERT INTO shp_mcd_centroids (mcd_name, "type", the_geom)
    SELECT
    DISTINCT
        mcd_name,
        "type",
    FROM
        shp_mcd
    GROUP BY
        mcd_name,
        "type"
Result
psql:temp.sql:5: NOTICE:  CREATE TABLE will create implicit sequence
"shp_mcd_centroids_gid_seq" for serial column "shp_mcd_centroids.gid"
psql:temp.sql:5: NOTICE:  CREATE TABLE / PRIMARY KEY will create implicit
index "shp_mcd_centroids_pkey" for table "shp_mcd_centroids"
CREATE TABLE
                          addgeometrycolumn
 public.shp_mcd_centroids.the_geom SRID:26915 TYPE:MULTIPOINT DIMS:1
(1 row)
psql:temp.sql:19: ERROR:  new row for relation "shp_mcd_centroids" violates
check constraint "enforce_geotype_the_geom"
