[postgis-users] AddGeometryColumn and Create Type
George Silva
georger.silva at gmail.com
Wed Jul 15 15:54:21 PDT 2009
Hello Gianvito,
AddGeometryColumns does an additional operation, which is updating the table
public.geometry_columns, used by most of OS GIS software to find out what is
the column that contains the geometry, it's type and SRID. Also this
function creates all the constraints necessary to use these softwares and
edit these geometries in an error free way.
Well you should create your type in a normal way, but it will be impossible
(i'm not 100% sure, just 95%) to use GIS software to edit geometries. You
will need to use another way to acess your geometries and insert/edit them.
If the type is for other purposes, i guess you should be fine.
I'll let others more experienced to give their toughts.
George
George R. C. Silva
Desenvolvimento em GIS
www.sextantegeo2.blogspot.com
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090715/4fca996a/attachment.html>
