[postgis-users] Indexes on table with 200,000 rows
Paul Austin
mail-lists at revolsys.com
Fri Jul 17 09:58:13 PDT 2009
I have a table with a geometry column in BC Albers (3005) for which I have
created a GIST index. I'm using postgresql 8.3.7 with Postgis 1.3.5-1.
CREATE INDEX my_table_geom_gist
ON my_table
USING gist
(geom);
I ran the VACUUM ANALYZE on the table.
When I run the following it shows a sequential scan rather than an index
scan.
explain SELECT geom FROM my_table WHERE geom && 'BOX3D(250982 1754957,
1369941 482671)'::box3d
Ultimately I want to be able to query using the ST_Intersects function but
if the index is not being used with the && operator then it's unlikely to
using the index with ST_Intersects.
In some forum posts there was a gist_geometry_ops option when creating
indexes but that doesn't seem to work with the version I have.
What are the real secrets to get postgis to use spatial indexes? Or do I
just not have enough data in my tables?
Paul
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090717/8491bc11/attachment.html>
