[postgis-users] Precision problem
Maxime van Noppen
maxime at altribe.org
Sat Jul 18 09:50:08 PDT 2009
Hello,
I face what I think is a precision problem. I have a point and a polygon
and I test whether the point is within the polygon or not. When both
geometries are in WKB, ST_Within returns false whereas when they are in
WKT it returns true.
WKB :
# SELECT ST_Within('010100000013898E0BA7E833C1FF843EA52C212C41', '
0103000000010000000400000000000000A09134C10000000088212A4100000000A0E832C10000000000812A41000000005E0634C1CDCCCCCC79512C4100000000A09134C10000000088212A41');
st_within
f
(1 row)
WKT :
# SELECT ST_Within('POINT(-1304743.04514367 921750.322742611)',
'POLYGON((-1348000 856260,-1239200 868480,-1312350 927932.9,-1348000
856260))');
st_within
t
(1 row)
The point is on the border of the polygon and I found that using DWithin
with 0 as tolerance makes both test work :
WKB :
# SELECT ST_DWithin('010100000013898E0BA7E833C1FF843EA52C212C41',
'0103000000010000000400000000000000A09134C10000000088212A4100000000A0E832C10000000000812A41000000005E0634C1CDCCCCCC79512C4100000000A09134C10000000088212A41',
0);
st_dwithin
t
(1 row)
For now I'll use this solution but I find it quite hacky. Is this a
normal precision-related behaviour ?
Thanks,
yabo
